17261 Discussions
cannot fit the design in the device Cyclone V
AbdAllahMohamed
i synthesis my design at synplify pro and then i fetched the VQM netlist and start fitting the design at Quartus.  i got an error that there are two bits in a module at the design it can not be fit at the design i tried alot of fitting options but there is no solution
FPGA is not fully utilized  and i didn't see anything wired at the two bits that the tool said
Thanks in advance
AEsqu
That Cyclone V (or Quartus) has so many problem to route signals ...
I never seen such routing issue with any other FPGA's ...
ShengN_Intel
Check out these two previous similar forum issues probably can help you.
https://community.intel.com/t5/Programmable-Devices/While-running-the-cyclone-V-the-following-routing-problems-are/m-p/734484
https://community.intel.com/t5/Programmable-Devices/Fitter-can-t-fit-a-small-design-in-Cyclone-V-SE-that-fits-in-a/m-p/1315600
May check on the link below as well.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/wvpr20k_vpr_no_route_suggestion_message.htm
CAUSE: The Fitter was unable to route the design because it requires too many device routing resources.
ACTION: There are multiple ways to diagnose or resolve a routing problem. Use one of the following methods to diagnose the routing problem:
  • View the Global Routing Wire Utilization Map in GUI for overall routing congestion.
  • View the Report Routing Utilization in Chip Planner for detailed routing congestion.
  • Investigate signals identified by the router.
  • Turn off timing optimization or alternatively just hold optimizations to see if timing constraints are the issue.
  • Investigate non-global large fanout nets.
Use one of the following methods to resolve the routing problem:
  • Reduce routing demand by modifying the design. Reduce the interconnect complexity by localizing routing as much as possible. For example, transform a cross-bar interconnect into a ring-style interconnect to reduce interconnect complexity and improve routability (at the cost of increasing latency).
  • If a global signal is unroutable, then delete global promotion of that signal.
  • Add or remove Logic Lock regions.
  • Reduce very aggressive timing constraints.
  • Cut timing paths on cross-clock transfers.
  • Change the Fitter Initial Placement Seed in the Advanced Fitter Settings dialog.
  • Enable the Fitter Aggressive Routability Optimizations logic option in the Advanced Fitter Settings dialog.
  • Reduce logic utilization.
  • Select a larger device.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
May I know any update? Do the suggestions help?
AEsqu
Still difficult to route using different actions like mentioned above but I can work with.
Either the Cyclone V has limited routing capabilities, either Quartus has a bug.
ShengN_Intel
Have you try with below compiler settings before:
OPTIMIZATION_TECHNIQUE AREA (Balanced to Area)
OPTIMIZATION_MODE "AGGRESSIVE AREA"
SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 2 (3 to 2)
ALLOW_SHIFT_REGISTER_MERGING_ACROSS_HIERARCHIES ALWAYS (Auto to Always)
PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION OFF (ON to OFF)
Allow Register Duplication (Off)
Remove Duplicate Registers (On)
Auto Register Duplication (Off)
Logic Cell Insertion - Logic Duplication (Off)
Perform Register Duplication for Performance (Off)
Fitter Aggressive Routability Optimizations (Always)
Auto Packed Registers (Minimize Area with Chains)
Optimize IOC Register Placement for Timing (Pack All IO Registers)
Perform Logic to Memory Mapping for Fitting (On)
Check also chip planner as well must be some place highly hotspot.
AEsqu
OPTIMIZATION_TECHNIQUE AREA (Balanced to Area) => tested already
OPTIMIZATION_MODE "AGGRESSIVE AREA" => tested already
SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 2 (3 to 2) => NOT tested, will try it
ALLOW_SHIFT_REGISTER_MERGING_ACROSS_HIERARCHIES ALWAYS (Auto to Always) => NOT tested, will try it. Note that my main netlist is from Synplify .vqm and that the congestion is in the cortex M33 in that netlist.
PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION OFF (ON to OFF) => tested already
Allow Register Duplication (Off) => tested already
Remove Duplicate Registers (On) => tested already
Auto Register Duplication (Off) => tested already
Logic Cell Insertion - Logic Duplication (Off) => tested already
Perform Register Duplication for Performance (Off) => tested already
Fitter Aggressive Routability Optimizations (Always) => tested already
Auto Packed Registers (Minimize Area with Chains) => tested already
Optimize IOC Register Placement for Timing (Pack All IO Registers) => NOT tested, will try it
Perform Logic to Memory Mapping for Fitting (On) => NOT tested, will try it
AEsqu
BTW, is there a way to tell Quartus to directly use the max optimization effort?
I use standard fit already.
It is never able to fit on first run, so I would like the tool to use the second strat immediately.
ShengN_Intel
There is only optimization mode.
Also, may be you can use larger capacity cyclone v device with more ALMs, Total I/Os, GPIOs, Memory Bits, DSP Blocks.
AEsqu
What do you mean by "There is only optimization mode."
We already use the biggest Cyclone V and we won't change it anyway.
AEsqu
These are the closest .qsf accepted values I found for the Cyclone V and Quartus 21.1.0 std version:
set_global_assignment -name CYCLONEII_OPTIMIZATION_TECHNIQUE AREA
set_global_assignment -name OPTIMIZATION_MODE "AGGRESSIVE AREA"
set_global_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 2
set_global_assignment -name ALLOW_SHIFT_REGISTER_MERGING_ACROSS_HIERARCHIES ALWAYS
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION OFF
set_global_assignment -name ALLOW_REGISTER_DUPLICATION OFF
set_global_assignment -name REMOVE_DUPLICATE_REGISTERS ON
set_global_assignment -name ROUTER_REGISTER_DUPLICATION OFF
set_global_assignment -name ROUTER_LCELL_INSERTION_AND_LOGIC_DUPLICATION OFF
set_global_assignment -name FITTER_AGGRESSIVE_ROUTABILITY_OPTIMIZATION ALWAYS
set_global_assignment -name QII_AUTO_PACKED_REGISTERS "MINIMIZE AREA WITH CHAINS"
set_global_assignment -name OPTIMIZE_IOC_REGISTER_PLACEMENT_FOR_TIMING "PACK ALL IO REGISTERS"
set_global_assignment -name INFER_RAMS_FROM_RAW_LOGIC ON
ShengN_Intel
Could you provide the .fit.rpt for taking a look?
Thank you,
Sheng
AEsqu
Let me know how to send it in private.
ShengN_Intel
You could provide the fitter report personally to me via this email id qi.sheng.ng@intel.com
ShengN_Intel
After going through the fitter report, looks like still not that extremely compact yet should be not a problem for routing.
Btw, glad to know that you have successfully route the design after a retry.
Thank you,
Sheng
AEsqu
In the logic lock region in blue , when it fails to route the Cortex M33, there are high wire utilization.
ShengN_Intel
The Compiler's messages contain information about average and peak interconnect usage. Peak interconnect usage over 75%, or average interconnect usage over 60%, can indicate difficulties fitting your design. Similarly, peak interconnect usage over 90%, or average interconnect usage over 75%, show increased chances of not getting a valid fit.
Based on the picture, I think your design should be no problem at routing for the time being.
Do let me know if you need any further help on this.
Thank you,
Sheng
