17266 Discussions
cannot launch modelsim software from quartus tool
NGoud
in-spite of providing the correct path of modelsim software, its not working
AnandRaj_S_Intel
Hi @NGoud​ ,
Configure Quartus II to work with ModelSim-Altera in native link mode:
·        On the Tools menu, click Options. The Options dialog box appears.
·        In the General list, select EDA Tool Options.
·        For ModelSim-Altera, type the path or browse to the directory containing ModelSim-Altera. The directory should be located under the Altera directory,        e.g. C:\<Quartus installation directory>\\modelsim_ase\win32aloem
·        Select OK.
Also try by stetting PATH environment variable PATH=C:\<Quartus installation directory>\modelsim_ase\win32aloem.
Which version and edition of quartus are you using?
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
NGoud
I had provided the modelsim.exe path and when i wanted to run the simulation tool it's giving native link error: did not specify the path to the executables.
Niharika
AnandRaj_S_Intel
Can you attache some image which show your settings?
Have you flowed above mentioned steps?
Please refer image for setting
Anand
NGoud
Thanks, its working now.
NGoud
hey, @Anand​
In qsys tool, in the library ->generic component was not found of quartus 17.0 how can i find it?
AnandRaj_S_Intel
@NGoud​
Which IP's can you name it.
Which edition of quartus 17.0(Lite,std,&pro)?
Anand
NGoud
I'm using quartus prime standard edition 17.0
In qsys -> IP Catalog , libraries section ->(generic component ->black box)
i couldn't find the generic component option
AnandRaj_S_Intel
​Hi @NGoud​ ,
Generic component  is only available in Quartus pro.
