Hi everybody;
i am newbie and have Nios II Embedded Evaluation Kit, Cyclone III edition. i am trying to add extra memory slot and added cfi_flash and sdram on my SOPC design. But in quartus II 8.0, i need to use pin planner but i dont know where pins are need to be connected. Thanks for help.Link Copied
Look at In schematics of Nios II Embedded Evaluation Kit, Cyclone III edition .... in Altera web site (a little hard to find, but they exist).
As you said it is hard to find and im newbie
altera web site > products > dev ktis > all dev kits > nios ii...cyclone iii edition > (http://www.altera.com/products/devkits/altera/kit-cyc3-embedded.html)
Is it yours ? If yes, you will see et the bottom, design files (http://www.altera.com/literature/tt/neek_sopc_builder_hw_lab.zip) ;-)- Mark as New
Answer is yes and im now looking on Documentations but again as you said it is hard to find pins usage
i downloaded the files you linked. im going to work on them. i hope to find something useful thanks for reply.- Mark as New
i looked the files and they are built in quartus 2 9.0 but im using 8.0
Look at .qsf file in the project. You can open it with notepad.you will find pin locations to cfi_flash
it may be silly but i need to ask.
this design and documentation has 2 dqs pins but when i opened my design's pin planner there are 4 dqs pins appears. do you have any idea?- Mark as New
Maybe DDR sdram is not the same.
I read again your 1st post (http://www.alteraforum.com/forum/showpost.php?p=114697&postcount=1), What do you mean by "to add extra memory slot and added cfi_flash and sdram on my SOPC design." ? Do you mean a 2nd DDR SDRAM ? Do you design your own board from this dev kit ?- Mark as New
--- Quote Start --- it may be silly but i need to ask. this design and documentation has 2 dqs pins but when i opened my design's pin planner there are 4 dqs pins appears. do you have any idea? --- Quote End --- If your dqs pins are ending with 'n' and 'p' they are differential. Very likely for DDR. In that case, one dqs signal need 2 pins (one 'p' and one 'n'). Cheers, Ton
Thanks Ton;
Can you explain what do you mean with "one dqs signal need 2 pins" ? What should be the connections to these dqs pins?- Mark as New
What I mean is that DQS signal are usually differential. This means you need 2 conductors in a pair to connect one signal. For a comprehensive explanation check: http://zone.ni.com/devzone/cda/tut/p/id/3407#toc2
good luck, Ton
