17255 Discussions
signal II tap issue with I/O BUS
Hello and thanks for any help.
I am using signal II tap to debug an I/O Bus between FPGA and DSP. My design works fine in timing simulation and I do see my "BUS~result" showing count up to the DSP synchronized to a common clock between the two devices.
However in signal II tap my bus is always showing <0000>, the weird thing is that if I tap into the count signal that feeds the BUS signal I do see the count up working but not on the actual BUS signal.
Any remarks are greatly appreciated.
thx,
Mowa...
Are you sure the count signal is feeding the output pins? are these pins bidirectiona? if so are you actually driving them?
Thanks for the reply,
I am pretty sure I am driving them and the timing simulation confirms, the bus is bidirectional. I wonder if there is something funny about the PINS in S2T?
May be you better start with a fresh signaltap.
I asked about bidirectional pins because a pitfall may occur if you are not driving it correctly at the right time. It could be the DSP chip is driving it with zeros.
thanks,
I will give it a shot. Are you aware of any special case where S2T can't access a Bidirectional Bus because some XYZ reason?
