ckeck clock existent
I have two clock domains in my design 1. variable clock ~64Mhz (driven from external pll)
2. 100mhz stable clock.
Does anybody have an idea how to check clock 64M existent ( without attaching it to a pll) ??
sampling 64M with 100Mhz will creat a metastability.
thanks
Yes it will create a metastability, that you can control by using several registers in cascade, all clocked at 100MHz. 3 stages should be enough. Just Google a bit for "clock domain crossing".
This is what I did, I sampled ~64Mhz clock with the stable 100Mhz. 3 samples.
I made a shift register with 5 stages. after that I compared the 5bit vector to "11111" or "00000" . if its true it means there is no toggling in 64Mhz.
Many thanks
