close loop at Test Bench
Hi ,
i want to close loop back at the Test bench between the transmitted data from transmitter to the receiver .
both transmitter and receiver implemented at VHDL and they are known to the top .
a,b - output ports
c,d - input ports
i instantiate the output from transmitter entity - serial_out is the output of the generator entity inside transmitter entity :
serial_out => a ;
i instantiate the output from top entity :
a => b ;
i instantiate the output b to input of the top from test bench to close the loop :
b => c ;
i instantiate the input from top entity :
c => d ;
i instantiate the input from receiver entity - serial_in is the input of the receiver sub entity inside receiver entity:
d=> ser_in ;
after simulation at modelsim there are error massage :
" Unknown formal identifier " for a,b,c,d .
what did i do wrong ?
do i need to instantiate the program deferentially ?
file attached .
have you declared a,b,c,d in your code for testbench?
Post the code...
Hi ,
The last scheme i added was general .
I added now the scheme of my project and code is relevant for this scheme (attached file ) .
The code of : Test Bench , Top, Tx , Rx , PN_Generator , Meta_Fix is also attached at files .
all of them are entities at different files .
The names of I/O ports at visio are the same at code .
The errors at Modelsim are :
1.after compiling testbench :
** Error: D:/Final Project/Technical/Top/simulation/modelsim/TestBench.vhd(49): (vcom-1035) Formal port "ser_in1" has OPEN or no actual associated with it.
2.after compiling top :
** Error: D:/Final Project/Technical/Top/hdl/top.vhd(30): (vcom-1484) Unknown formal identifier "ser_in1".
3.After compiling Rx
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(33): (vcom-1484) Unknown formal identifier "ser_in".
When compile the transmitter alone the result were proper serial data at ser_out .
attached the rest of the files .
--- Quote Start ---
--- Quote End ---
you haven't connected ser_in of top.
you only connected ser_out to ser_in1.
ser_out is now driving ser_in1 but then ser_in1 must drive ser_in of top
Hi kaz ,
i did connect between ser_in1 to ser_in .
look at row 30 at top file :
ser_in1 => ser_in , --in std_logic
thanks for your assistance .
--- Quote Start ---
Hi kaz ,
--- Quote End ---
you are mixing up between names.
ser_in is not a port, you are just driving it from internal signal that is not driven.
just connect as I told in my above post.
you need to connect ser_in1 of your rx module to serial_in1 port of top.
Then in testbench, connect ser_in1 to say "temp" signal then connect temp to ser_out.
In your testbench then I assume you drive ser_out with some data internally to be received by Rx
ok ,
i connect : ser_in1=>ser_in at test bench file and now it compile without errors.
i connect : ser_in => data_in at top file ( ser_in1 is the input port to the top ) .
i declare data_in as a signal at the top file - signal data_in : std_logic; and now top file compile without errors .
At the Rx file ser_in as input port ,
At the Rx file i declare data_in as signal and connect : Data_in=> Data_in_D .
There are 11 errors at Rx file after compiling .
one of the errors is :
1. ** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(34): (vcom-1136) Unknown identifier "Data_in_D".
Data_in_D is the input port to MetaFix - declared at Rx file . i tried to declare it as a signal at Rx file but still it has the same error .
2. The rest of the errors related to the other signals at Rx Entity/file :
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(45): (vcom-1484) Unknown formal identifier "reg_in_signal1".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(53): (vcom-1136) Unknown identifier "cmp_in_Tx".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(54): (vcom-1136) Unknown identifier "cmp_in_Rx".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(53): (vcom-1484) Unknown formal identifier "cmp_in_signal1".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(54): (vcom-1484) Unknown formal identifier "cmp_in_signal2".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(62): (vcom-1484) Unknown formal identifier "seed_en_out".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(70): (vcom-1484) Unknown formal identifier "PN_out2".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(78): (vcom-1484) Unknown formal identifier "cmp_out".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(80): (vcom-1484) Unknown formal identifier "seed_en_out".
** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(84): VHDL Compiler exiting
i define all of this names as signals at Rx Entity but still there are errors .
what should i do about both cases ?
attached the hdl files project .
add scheme
--- Quote Start ---
--- Quote End ---
No it is not declared in rx_vhd. It is port to submodule(Metfix). Thus it is unknown at rx_vhd.
Just make a search for every errored signal and see if it is declared.
Hi kaz ,
i'm a little confused ... i did defined data_in , data_in_D and all the rest of the signals as signals at Rx.vhd and still there are many errors .
lines 17-26 at Rx.vhd :
signal Data_in_D : std_logic;
signal PN_in : std_logic; -- PN_in is the output of the block PN_Transmitter
signal cmp_out : std_logic; -- cmp_out is the output of the block comparator
signal reg_in :std_logic;
signal reg_in_signal1: std_logic;
signal cmp_in_signal1: std_logic_vector(7 downto 0);
signal cmp_in_signal2: std_logic_vector(7 downto 0);
signal x : std_logic; -- x is the comparator output
signal PN_out2 : std_logic; -- PN_out2 is the second PRBS output
what do i need to do more ?
The error relates to the metafix entity. It has no port called data_in, its called data_in_d.
And I suspect the rest of the problems are similar (you named the ports incorrectly, not the signals.
On another note - some of these connections do nothing. For example, in RX, the data_in_d signal is connected to nothing.
i changes the instanstiation order and now it compile without errors .
Thanks a lot guys , you're awesome !
