17255 讨论
compilation error (kernel32.lib) on Visual Stdio 2012
名誉分销商 II
1,517 次查看
When I run the OpenCL 13.1 project on Visual Stdio 2012 on Terasic's DE5-Net board, the compilation error shows up: link : fatal error lnk1181: cannot open input file 'kernel32.lib'; no compilation error on Visual Stdio 2010.
0 项奖励
1 回复
名誉分销商 II
784 次查看
Go into the Visual Studio linker settings and remove kernel32.lib from the library list. I'm guessing Microsoft removed that library or they moved it to a different location that isn't being referenced. This assumes you do not rely on anything that is contained in kernel32.lib
0 项奖励
回复
