17247 Discussions
continue process after end of file
goodmorning,
I have created a testbench importing data from a .bin file.
These data are loaded in a RAM, and then analyzed by a second process. The time for analyzing all data is more than the time to upload them in the RAM.
I have written the process to extract data from file in this way:
begin
if not endfile(input) then
wait for clockRAM*4;
for i in 0 to 7 loop
read(datafile, indata);
inputvariable<=CONV_STD_LOGIC_VECTOR(character'pos(indata),8); --I extract 8 byte at a time.
end loop;
else
file_close(datafile);
wait;
end if;
end process;
I would that the simulation doesn't stop when the datafile is ended, but I would wait the end of the data analysis, which is in another process; But when datafile is ended I receive a message of fatal error.
How can I do?
Dario
PS. I'm using Modelsim simulator v.10.1
you didnt say what thye error is?
I do notice though that in your code you have no waits between read values. Signals are only updated when a process suspends, so your current code read 8 values from a file but will only put the 8th value onto inputvariable (this is a silly name for a signal, as it is not a variable).
you are right. The error is: "Attempt to read past the end of file." In my code the inputvariable is called Macoutput, because the MAC inteface extract 8 bit for clock cycle. Every 96 ns I begin to extract the first 8 bits of a Payload which is - in my case - 64 bit long. Then they are saved in eight registers and finally a fifo is filled. But these are details. The important thing is that the simulation should go on when the read file is at the eof.
You havent posted the whole code, so I can only go off what you have posted:
- You check for end of file from a file called "input" but you read from a file called "datafile".
- Are there enough values in the file? You only check for end of file every 8 values - so is the total length of the file divisible by 8?
- Your code will not do what you're talking about. Because signals are only assigned when a process suspends, according to your code "inputvariable" is only assigned the 8th value, the first 7 are discarded. and you're talking about reading bits - do you mean reading bytes?
- You also wait for a specified period of time. Does this sync up with the clock properly? why dont you wait for a rising/falling edge of a clock?
Fantastic!! You are right again... I'm a stupid man! I've write the wrong name of the file.... I'm really sorry :'(
Thanks a lot, and sorry again for my poor figure!
