17255 Discussions
converting a signed shift amount to unsigned
I got a lot of warnings about combinational loops as latches of the design (via pipelining). If the loops were created on purpose (e.g. iteration), Is this kind warning normal? Is there a way to remove things like this? Actually, these loops also includes flip-flops
Hi JenC
If you can provide a code example we may be able to help you better. In general latches are frowned upon in FPGA/ASIC design today. Many times these in-inadvertently occur in combinational always blocks with case statements, when no default case exists:
IE:
always @(*) begin
case (state_r)
3'b000 : output_c = 1'b1;
3'b001 : output_c = 1'b0;
endcase
end
In this case output_c is a latch, since there is no "default" in the case statement, output_r must hold it's previous value for all non-defined state_r conditions.
This can be fixed by defining a default condition like:
always @(*) begin
case (state_r)
default : output_c = 1'b0;
endcase
end
Or by pre-defining a default condition in the blocking assignments as:
always @(*) begin
output_c = 1'b0;
case (state_r)
endcase
end
The warning is telling you you have this kind of thing happening in your design. So you should be looking at it and seeing if you REALLY intended it to be a latch.
Pete
--- Quote Start ---
--- Quote End ---
Some confusion seems to be involved. Pipelining uses a clock and infers synchronous registers, never latches. Show the code!
