counting input signals
hello there,
I'm quite new to the fpga world, and i have run into a problem. The idea is that I want to count incoming impulses on pin1 per second (frequency varies from 200~ to 1000hz) , and then display that number on a 7segment display.
Im using the schematic layout thing.
1.I made a counter, that converts 50Mhz onboard clock to 1Hz signal.
2.A second counter (10bit) counts the impulses on pin1, and resets when it receives aclr signal ( the 1Hz signal)
3.A latch, that allows data to flow through when it receives the same 1Hz signal. aswell as a bcd converter to display the numbers.
Now the problem is clock skew > data delay. failed paths.. why oh why does this happen. I think that quartus somehow thinks of my pin1 signals as a second clock or something. What can i do ?
Maybe you'd better post your schematic.
Here goes nothin:
module tau( input clk, output reg Hz); reg cnt; always @(posedge clk) begin if (cnt == 50000000) begin cnt <= 0; Hz <= 1; end else begin cnt <= cnt+1; Hz <= 0; end end endmodule module bcd( input data, output reg seg); reg z; integer i; always @(posedge data) begin z = 0; z = data; for (i=0; i <= 6; i = i+1) begin if (z > 4) z = z + 3; if (z > 4) z = z + 3; if (z > 4) z = z + 3; z = z; end seg=z; end endmodule module leddisplay(data, A1, B1, C1, D1, E1, F1, G1); input data; output wire A1, B1, C1, D1, E1, F1, G1; reg first; reg Sevenseg1; always @(posedge data) begin first <= data; case(first) 4'b0001: Sevenseg1 = 7'b0000110; //1 4'b0010: Sevenseg1 = 7'b1101101; //2 4'b0011: Sevenseg1 = 7'b1111001; //3 4'b0100: Sevenseg1 = 7'b0110011; //4 4'b0101: Sevenseg1 = 7'b1011011; //5 4'b0110: Sevenseg1 = 7'b0011111; //6 4'b0111: Sevenseg1 = 7'b1110000; //7 4'b1000: Sevenseg1 = 7'b1111111; //8 4'b1001: Sevenseg1 = 7'b1110011; //9 default: Sevenseg1 = 7'b0000000; endcase end assign {A1,B1,C1,D1,E1,F1,G1} = Sevenseg1; endmoduleLeddisplay obviously only shows one digit, but ignore that.
Warning: Found 3 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew
Info: Detected ripple clock "lpm_latch0:inst2|lpm_latch:lpm_latch_component|latches[0]" as buffer
Info: Detected ripple clock "bcd:inst3|seg[0]" as buffer
Info: Detected ripple clock "tau:inst1|Hz" as buffer
Well, it's pretty clear from the schematic that "inputs" is being used as the clock signal to lpm_counter0.
So, that part is pretty straightforward.
In your "bcd" and "leddisplay" have a weird sensitivity list: always @ (posedge data).
I'm not sure this behaviour can actually be mapped into hardware, since data is a bus, not a signal.
And in any case, it's not what you want. With this code, the output's will only change when one of the "data" bits goes from 0 to 1, but not the other way arround.
You problably want to use always @ (*) to describe combinational logic.
Finally, I advise against using latches in FPGAs as much as possible. Use a flip-flop with a clock enable.
Thanks for the answer. I will try the "always @ (*)" .
Can a flip-flop be used for a data stream ? I suppose i need a way to only work with the final sum of the impulses
I don't quite understand the question.
well, i need to count up the impulses, and then work with that number(display it, maybe add something, etc).
From what i know, a flip-flop can store only 1 bit of information (My understanding can be wrong here). In this case I have 10bits worth of data, that i have to pass to the bcd each second.
Maybe you could post a code, or something like that. I would really appreciate it!
Ah, I understand your doubt now.
Well, both an elementary latch and a flip-flop store just a single bit.
The lpm_latch0 element you have in your design is an array of 10 latches. My suggestion was to replace it with an array of 10 flip-flops.
Got it!
Is there a preset element in the schematic builder for that?
I am clueless regarding schematic (I always used HDL).
ok I also got it
--- Quote Start ---
Got it!
--- Quote End ---
such elements are available. You have two choices :
1. When you double click in your schematic a windows opens. On the left side you couls see a folder called : ....../libraries. Under the subfolder "primitives" you find a folder "storage".
There you can select "dff" for a register and place the symbol in your schematic. When you connect the register to a bus Quartus recognice the number of register automatically.
2. You can use the Megawizard Plug-in Manager:
Under Tools choose "Megawizard Plug-in Manager". Under Storage choose LPM_FF and go through all the tabs. The Megawizard generates a symbol for the register. Again double click into your schematic. You will find the symbol foe the register in the folder "Projec
t".
Kind regards
GPK
Thanks! I'll try that asap
Awesome, everything works! thank you so much.
Now maybe somebody could tell me how to control a 7 segment led display? I don't understand how to select and controls pins, so that they would act as GND when I need them to?
