17253 Discussions
create bdf Symbol from SV module with Interface using
Trying to use SystemVerilog Interfaces.
Create main.sv file with test sources content:
interface main_bus;
    wire [15:0] data;
    wire [15:0] address;
    logic [ 7:0] slave_instruction;
    logic slave_request;
    logic bus_grant;
    logic bus_request;
    logic slave_ready;
    logic data_ready;
    logic mem_read;
    logic mem_write;
endinterface
module processor (
// main_bus interface port
main_bus bus,
// other ports
input logic clock,
input logic resetN,
// ... // module functionality code
endmodule
so if I try tool File-Create-CreateSymbolFileForCurrentFile then I'l get error:
error (10016): can't create symbol/include/instantiation/component file for module "processor" because port "bus" has an unsupported type
What I miss? or BDF just doesn't support SystemVerilog Interfaces feature?
P.S. sorry for my English.
i don't expect you will get away with advanced types like this in a .bdf. there are also limitations with the VHDL types allowed
you can either port signals out in basic types, or use SystemVerilog instead of .bdf
well.. thanks anyway.
so now I can stop looking for answer and rewrite project and use SV text file in TOP of the project instead bdf.
BDF support for HDLs is pretty poor, and because you cannot do RTL simulations its best to avoid them anyway.
I think it's possible to use a struct
or whatever else signals with concatenation at output.
like that:
struct { logic [7:0] adr;
logic [15:0] data;
logic rd;
logic wr;
} bus;
wire [25:0] bus_out = {bus.data, bus.adr, bus.rd, bus.wr};
and then use bus_out as module output.
am I wrong?
