hi,
im a newbie by using quartus II and also vhdl code, im reading a book is CIRCUIT DESIGN IN VHDL to learn :) i need to implement the vhdl code in quartus II, im confused by compiling the vhdl package am i create a library in C:\altera\61\quartus\libraries ? or just add the package in Project>Add/Remove Files in Project. could you help me?:confused: and if there is a tutorial that is using vhdl with vhdl package in quartus II,it will be helpful for me. this is the package(mult_package.vhd) LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; PACKAGE pack IS FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED; END pack PACKAGE BODY pack IS FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED IS CONSTANT max: INTEGER :=a'LENGTH + b'LENGTH - 1; VARIABLE aa: UNSIGNED (max DOWNTO 0):= (max DOWNTO a'LENGTH =>'0') & a(a'LENGTH-1 DOWNTO 0); VARIABLE prod: UNSIGNED(max DOWNTO 0):=(OTHERS => '0'); BEGIN FOR: IN 0 TO a'LENGTH-1 LOOP IF (b(i)='1') THEN prod:=prod+aa; END IF; aa:= aa(max-1 DOWNTO 0) & '0'; END LOOP; RETURN prod; END mult; END pack; and the main code (multiplier.vhd) LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE work.mult_package.all; ENTITY multiplier IS GENERIC (size: INTEGER := 4); PORT (a,b:IN UNSIGNED(size-1 DOWNTO 0); y:OUT UNSIGNED(2*size-1 DOWNTO 0)); END multiplier; ARCHITECTURE behaviour OF multiplier IS BEGIN y<= mult(a,b); END behaviour; im confused about using the libraries were created there are the steps that i did. created a project named multiplier then write these two in text editor then i add these in project>add/remove files in project then start compilation these errors belongs to mult_package.vhd file Error (10500): VHDL syntax error at mult_package.vhd(7) near text "PACKAGE"; expecting ";" Error (10500): VHDL syntax error at mult_package.vhd(8) near text "IS"; expecting ";" Error (10500): VHDL syntax error at mult_package.vhd(14) near text "BEGIN"; expecting "end", or a declaration statement Error (10396): VHDL syntax error at mult_package.vhd(21): name used in construct must match previously specified name "pack" Error (10523): Ignored construct pack at mult_package.vhd(4) due to previous errors Error (10500): VHDL syntax error at mult_package.vhd(22) near text "END"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" thank you.Link Copied
1. An error message ending with expecting ";" usually exactly means, you forgot a ";".
2. As with many other programming languages, succeeding errors should be reviewed after correcting the first. 3. The correct package reference would be in your caseLIBRARY work;
USE work.pack.all;
4. As you already found out, project specific package code normally would be placed in the project directory.
thank you for your help.
--- Quote Start --- this is the package(mult_package.vhd) LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; PACKAGE pack IS FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED; END pack; PACKAGE BODY pack IS FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED IS CONSTANT max: INTEGER :=a'LENGTH + b'LENGTH - 1; VARIABLE aa: UNSIGNED (max DOWNTO 0):=... --- Quote End --- i just forgot one ";" near END pack and that will solve the 4 of the errors then i change my package name as my_pack also in the code PACKAG my_pack; the PACKAGE name must be the same name of the file. i found it:) cheers these are solve my problems :) thank you for your interest- Mark as New
Alternatively, the function could be defined in main code declarative part. It's not generally necessary to define a package to use a function.
