- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Timing analyzer tool report that Recovery timing on reset synchronizer fail. I found I can apply the following false path assignment on the reset path:
set_false_path -to *dcfifo:dcfifo_component| dcfifo_*:auto_generated|dffpipe_*:wraclr|dffe*a[0] • set_false_path -to *dcfifo:dcfifo_component| dcfifo_*:auto_generated|dffpipe_*:rdaclr|dffe*a[0]
Is it necessary use this to avoid timing violation or is it some another way?
Lien copié
2 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
According to the user guide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf (Page 19), you have to apply the above two false path assignments on the reset path.
KhaiY
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Do you have any questions?
KhaiY
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
