17265 Discussions
ddr3 SRAM Controller with Uniphy intel FPGA IP 22.1 failed
jkhoo
Hi Intel team,
Please see below for the error message when i am generating the DDR3 IP.
<html>Info: "<b>MyDDR3_master</b>" instantiated <b>altera_mem_if_ddr3_phy_core</b> "<b>p0</b>"
<html>Info: "<b>MyDDR3_master</b>" instantiated <b>altera_mem_if_ddr3_afi_mux</b> "<b>m0</b>"
Error: Error during execution of "{C:/intelfpga/22.1std/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: Execution of command "{C:/intelfpga/22.1std/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: Nios II Command Shell.bat requires Windows Subsystem for Linux (WSL) to run.
Error: Please install WSL and try again.
Error: child process exited abnormally
Error: Cannot find sequencer/sequencer.elf
Can you help to advise how to solve this issue?
I notice it is asking me to install WSL. But my system already have WSL.
AdzimZM_Intel
AdzimZM_Intel
The WSL version and Ubuntu version look okay.
What is your OS build version?
Have you installed the distro packages for NIOS?
Can you provide the snapshot of the installation progress?
Last time I did encounter similar issue because the distro packages were not installed successfully.
Adzim
jkhoo
where to get distro packages for NIOS?
jkhoo
OS build version is windows 10  10.0.19045
AdzimZM_Intel
You can find the distro package on procedure 3 from this link: https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/installing-windows-subsystem-for-linux.html
Adzim
jkhoo
hi Adzim,
I install the distro package and Quartus Prime 22.1 is now working as expected.
Thank you very much, JJ
