defparam
榮譽貢獻者 II
1,474 檢視
Hi. I have several modules that used the parameter in my verilog design. However it is very troublesome to do the change the value of the parameter for every module involved. Is there any way just to declare it once only on the top module? Thanks.
0 積分
2 回應
榮譽貢獻者 II
709 檢視
Normally people use `define / `ifdef etc. to load the parameter values if this is required.
You can either set up the defines you want in a verilog file and include that at the beginning of the file list, or Quartus can set defines for you.
榮譽貢獻者 II
709 檢視
Thanks a lot.
回覆
