duplicate design
Hi ,
At my project i design system that generate PRBS data and lock at the transmiter PRBS data .
i used 11 files for the components of the design and after simulation ,synthesis and burning the .sof file at evaluation kit of ALTERA its work properley.
The system has input port - clock and i spread it throgh PLL to all components , another input port : serial_in from loop cards, and 2 output ports :
1 output port to transmit the data to loop card and lock to declare of PRBS lock .
The next thing i need to do is to duplicate this system to 2 or more systems at the top file .
i read about the : "for generate loop" command and about its uses and i think it can help me .
do i need to define the system as component and instantiate all the ports from the new top file ? what about the signals ?
how do i declare the system as component ?
Thanks .
Hi odedidush.
Yes. You have to use your design as a component and instantiate n times. You use the old top level entity as a component in another vhdl file.
For generate is like an automatic copy+paste:
name: for i in 0 to 7 generate
somename_unit : yoursystem port map
(... -- instantiation
end generate name;
Hi bertulus , i have some more questions .
i understand from you that i need to instantiate all the ports of the current Top file from another vhdl file .
do i instantiate the ports same as i instantiate it from the Test Bench ? what about the signals , do i need to instantiate them as well at the vhdl file ?
The design have one input clock at Freq=125MHz and it's connected to PLL that has two output at c0=25MHz and c1=100MHz .
if i create a new file with more similar components, will it be better to take the PL outL from the current top file and put it at the new vhdl file?
then the PLL will spread the c0,c1 to all new components .
the second option is to stay at this situation when the PLL is inside every component but then the design can have large number of PLL's .
i added the current Top file .
Thanks for your advice .
I understand top.vhd is the black box you need to replicate. I don't place a pll on every unit I have to instantiate. First, because the global circuit will have many clocks. If the unit have to communicate each other, they have different clock domain. You can avoid it. Second, you have a small numbers of pll in a fpga ( depends of the device ).
If I found in my hard disk, i post the code of an iterative circuit ( an incrementor ) made of a simple unit, replied N times. It's a good example of how to use for generate.
I not found the example i'm looking for, but i posted a similar one. It's a gray code incrementor. In the first file you find an elemental cell ( 1 bit gray incrementor ) and the other file instantiates it N times, using for generate. There are 2 extreme cases, the boundary conditions, so i use an if to made different these cells. Probably your code don't need that.
Hi bertulus ,
i did as you said , i duplicate the black box N times with all input and output ports .
about the clocks , the issue is that there is one clock input to the design and i used 1 PLL at the new vhd file.
The PLL has 2 output - c0,c1 that connected to each black box ,
The design has more than one black box and need to connect the PLL outputs (C0,C1) to each one of them .
i defined 2 signals of std_logic_vectors(1 downto 0) - PLL_lock_25M,PLL_lock_100M and connect them at the for generate loop :
dup : for i in 1 to 2 generate
one: Design port map
clk_in_25M => PLL_lock_25M(i-1)
clk_in_100M => PLL_lock_100M(i-1)
end generate ;
at the PLL instantiation i wrote :
pll1: entity.pll (behave) ... port map (
c0 => PLL_lock_25M
c1 => PLL_lock_100M
after compilation there is error at this section because c0,c1 are std_logic and PLL_lock_25M,PLL_lock_100M are std_logic_vector and the instantiation doesn't succeed .
what do you recommend to do ?
The clock should be std_logic, no std_logic_vector:
signal PLL_lock_25M,PLL_lock_100M : std_logic;
clk_in_25M => PLL_lock_25M,
end generate ;
c0 => PLL_lock_25M
c1 => PLL_lock_100M
Hi bertulus ,
i did as you said and define the clk_in and pll_25M_out, pll_100M_out as std_logic .
i publish the full new .vhd file that i create in order to duplicate the PRBS box . i also publish the design scheme at word file .
-- Top Design
library ieee;
use ieee.std_logic_1164.all;
entity TopDesign is
port(
clk_in : in std_logic;
ser_in1 : in std_logic;
lock_out : out std_logic;
ser_out : out std_logic
end entity TopDesign;
architecture Design of TopDesign is
signal pll_25M_out : std_logic; -- 25M output from PLL
signal pll_100M_out : std_logic; -- 100M output from PLL
signal PLL_locked : std_logic; -- when PLL_Locked = '0' it send resetN ='0' to all components
signal ResetN_25M : std_logic;
signal ResetN_100M : std_logic;
--signal debug_clk_in_test : std_logic;
begin
--The PLL instantiation is :
Top_level_pll: entity work.pll_125M (SYN)
port map(
inclk0 => clk_in , --in std_logic
c0 => pll_25M_out , --out std_logic
c1 => pll_100M_out, --out std_logic
locked => PLL_locked --out std_logic
Top_level_Meta_Reset_25M: entity work.Meta_Reset (behave)
port map(
locked => PLL_locked, --in std_logic
clk => pll_25M_out, --in std_logic
Din => '1' , --in std_logic
rst_n=> ResetN_25M --out std_logic
Top_level_Meta_Reset_100M: entity work.Meta_Reset (behave)
port map(
clk => pll_100M_out, --in std_logic
rst_n=> ResetN_100M --out std_logic
--The duplicate PRBS box instantiation is :
Top_level_Top: for i in 1 to 2 generate
duplicate:entity work.top(Design)
port map(
clk_in1=>pll_25M_out, --in std_logic
clk_in2=>pll_100M_out, --in std_logic
ResetN_25M => ResetN_25M, --in std_logic
ResetN_100M => ResetN_100M, --in std_logic
ser_in1 => ser_in1, --in std_logic
ser_out => ser_out, --out std_logic
lock_out => lock_out --out std_logic
end generate ;
end architecture Design;
After the simulation at Model Sim the signals and prots of top entity duplicate ( Top_level_Top(1) , Top_level_Top(2) ) .
i tried to use the duplicated ports at Quartus Pin Planner, F.E : ser_in1(2),ser_out(2) and the Quartus didn't find them .
i just want to be clear , as mentioned at the scheme , the topddesign have n ser_in1 input ports , n ser_out output ports and n lock_out outputs ports .
don't i need to define the inputs , outputs as std_logic _vector in order that Quartus will know that its more that one pin ?
in this situation does the input for every entity (i.e Resets, clocks ...) should be std_logic _vector as well ?
Thanks .
According to the word document you should not declare clock and resets as vector because are the same clock and reset for all instantiated modules. It's the same wire. But Ser_out and ser_in must be vector. Something like:
signal ser_in1 : std_logic_vector(1 downto 0);
signal ser_out : std_logic_vector(1 downto 0);
signal lock_out : std_logic_vector(1 downto 0);
port map(
ser_in1 => ser_in1(i - 1), --in std_logic
ser_out => ser_out(i -1), --out std_logic
lock_out => lock_out(i - 1) --out std_logic
Thanks a lot bertulus ,
i changed the code and the design work properly at simulation and after synthesis and burning the code to evaluation board .
