ecilpse ERROR
dui
i use Quartus Prime Lite20.1 to invoke ecilpse, which has installed under the tutorial. i use a hello world model.  When i start to build project, then i met the error:make: *** [Makefile:1011: hello_world_0.elf] Error 1.
In details:
wsl make all
wslpath: hal_bsp: No such file or directory
Info: Building /mnt/d/Intelprj/ex/nios2/software/hello_world_0_bsp/
make --no-print-directory -C /mnt/d/Intelprj/ex/nios2/software/hello_world_0_bsp/
[BSP build complete]
Info: Linking hello_world_0.elf
nios2-elf-g++.exe -T'D:/Intelprj/ex/nios2/software/hello_world_0_bsp/linker.x' -msys-crt0='D:/Intelprj/ex/nios2/software/hello_world_0_bsp/obj/HAL/src/crt0.o' -msys-lib= -LD:/Intelprj/ex/nios2/software/hello_world_0_bsp -Wl,-Map=hello_world_0.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global -o hello_world_0.elf obj/default/hello_world.o -lm -msys-lib=m
nios2-elf-g++.exe: error: missing argument to '-msys-lib='
David_G_Intel
Hello dui
Thank you for posting on the Intel️® communities.
For future requests, the support for Quartus Prime related issues is provided on a different forum. You can post your questions on the “Intel® Quartus® Prime Software” section:
We will move this post to the appropriate forum.
David G
Intel Customer Support Technician
