16684 Discussions
error while simulating in quartus
I'm trying to simulate a FSM, but I keep getting this error message:
"Error: Zero-time oscillation in node "|top|FSMcontrol:L1|Selector5~0" at time 50.0 ns. Check the design or vector source file for combinational loop."
Code:
library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity FSMcontrol is
port(
Clock_in: in std_logic;
Reset_in: in std_logic;
enable_reg: out std_logic;
Clk: out std_logic;
Rst: out std_logic;
enable_inc: out std_logic;
readd: out std_logic;
writee: out std_logic
end FSMcontrol;
architecture control of FSMcontrol is
type STATES is (s_reset,s_increment,s_enable,s_user_write,s_user_read,delay1,delay2,delay3,delay4,d_clock_1,d_clock_2,d_clock_3);
signal EA, PE: STATES;
signal atraso: std_logic_vector(27 downto 0);
begin
Clk <= Clock_in;
Rst <= Reset_in;
process (Clock_in, Reset_in)
begin
if Reset_in = '0' then
EA <= s_reset;
elsif Clock_in'event and
Clock_in = '1' then
EA <= PE;
end if;
end process;
process(EA)
begin
case EA is
when s_reset =>
enable_reg <= '0'; enable_inc <= '0'; readd <= '0'; writee <= '0';
PE <= delay1;
when s_increment =>
enable_reg <= '0'; enable_inc <= '1'; readd <= '0'; writee <= '0';
PE <= s_user_read;
when s_user_read =>
enable_reg <= '0'; enable_inc <= '0'; readd <= '1'; writee <= '0';
PE <= s_enable;
when s_enable =>
enable_reg <= '1'; enable_inc <= '0'; readd <= '0'; writee <= '0';
PE <= d_clock_1;
when s_user_write =>
enable_reg <= '0'; enable_inc <= '0'; readd <= '0'; writee <= '1';
PE <= s_increment;
when delay1 => atraso <= ( others => '0' );
PE <= delay2;
when delay2 => atraso <= atraso + 1;
PE <= delay3;
when delay3 => if atraso >= x"8F0D180" then PE <= s_increment;
else PE <= delay4;
end if;
when delay4 => PE <= delay2;
when d_clock_1 => PE <= d_clock_2;
when d_clock_2 => PE <= d_clock_3;
when d_clock_3 => PE <= s_user_write;
end case;
end process;
end control;
you cannot put counters in an asynchronous process.
--- Quote Start ---
--- Quote End ---
Oh, and how can I fix this?
put the counter in a synchronous process.
