I didn't find in the huge documentation the right way to setup my external editor (emacsclient) under cygwin to open the file correctly. Menu: tools / options / text editor / alternate editor Because of the eternal problem of \ and spaces in the filename path from Windows to Unix I would like Quartus to open the file on my emacserver with the CYGPATH not with the windows path because the emacsclient editor is unable to find it. So it opens a void buffer. My quartus is launched from a cygwin xterm so the server is correctly recognized. The problem remains the filepath that is passed to the client as "windows style" As the %f entered in the option field (%f no such matter found in doc!) represents the windows filename. I have tried a lot of tricks but all have failed. Is someone of you have a trick to workaround this ? Also why not to include in Quartus further releases a global env variable to say: Use ALWAYS unix style filenames ? that are quite well understood by both Os.Link Copied
Topic Options
