17267 Discussions
final procedure block does not work in ModelSim
SystemVerilog LRM (1800-2012):
--- Quote Start ---
A final procedure executes when simulation ends due to an explicit or implicit call to $finish.
--- Quote End ---
But the final block does not execute in ModelSim Altera Starter Edition 10.1e:cry:
I used the following code:
module test(); initial begin # 1 $display("Simulation has been started"); # 1 $finish; end final $display("This should be shown at the end"); endmodule
and this is the output:
# Simulation has been started# ** Note: $finish : C:/.../final_bug.sv(4)# Time: 2 ns Iteration: 0 Instance: /test
Are you running this code interactively? If so, $finish may be behaving like $stop.
By "interactively" you mean by using the ModelSim GUI, right?
By the way did you ever simulate a SystemVerilog code containing a "final block" with ModelSim? if not could you please try it and tell me the results?
thanks
Model Technology ModelSim SE qverilog 10.1e Compiler 2013.06 Jun 11 2013 /u/prod/release/10.1e/modeltech/linux/qverilog final1.sv -- Compiling module test Top level modules: test + /u/release/10.1e/modeltech/linux/vsim -lib work test -c -do run -all; quit -f -appendlog -l qverilog.log -vopt # vsim -appendlog -do {run -all; quit -f} -l qverilog.log -lib work -c -vopt test # ** Note: (vsim-3812) Design is being optimized... # // ModelSim SE 10.1e Jun 11 2013 Linux 3.0.13-0.27-default # // # // Copyright 1991-2013 Mentor Graphics Corporation # // All Rights Reserved. # // # // THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION # // WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS # // LICENSORS AND IS SUBJECT TO LICENSE TERMS. # // # Loading sv_std.std # Loading work.test(fast) # run -all # Simulation has been started # ** Note: $finish : final1.sv(4) # Time: 2 ns Iteration: 0 Instance: /test # This should be shown at the end
Thank You Dave!
I guess instead of using the GUI, you typed the tcl script and this time the output looks fine.
