- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
hi everybody.
sorry for my english. I ask for your help for released an simple frequency meter with vhdl (i am newbie on FPGA): https://alteraforum.com/forum/attachment.php?attachmentid=14027&stc=1 Input "ref_clock" is 50 MHz periode 20ns of cyclone IV E. "signal" is mesured signal from encoder Output cycle of test errors every 1 sec if frequency >= 1000 Hz ==>error1 = 1 //1 is logic HIGH if frequency >= 2000 Hz ==> error1 = 1 and error2 = 1 else error1 = 0 and error2 = 0 //0 is logic LOW thank you.Link copiado
5 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
What help do you need. What problems are you having?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
try google: fpga vhdl frequency measure
(hint: the second hit may be this one: http://surf-vhdl.com/compute-frequency-clock/)- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
thank you Tricky, josyb.
Tricky, how to do it in the simplest way possible. josyb, I didn't understand half of the code. I told you that I was newbie in(FPGA VHDL...) Here is my code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity freq_meter is
port (
i_ref_clock : in std_logic; -- 50 MHz
i_signal : in std_logic; -- from encoder
o_error1 : out std_logic;
o_error2 : out std_logic);
end freq_meter;
architecture freq_meter_arch of freq_meter is
begin
-- CLOCK REFERENCE domain
variable clock_secand_decounter : integer := 50000000;
variable i_signal_counter : integer := 0;
if(clock_secand_decounter<=1) then
if(rising_edge(i_signal)) then
i_signal_counter <=i_signal_counter+1;
if(rising_edge(i_ref_clock)) then
clock_secand_decounter <= clock_sec_dec -1;
end if;
end if;
end if;
if(clock_secand_decounter >= 1000)then
o_error1='1';
o_error2='0';
elsif(clock_secand_decounter >= 2000)then
o_error1='1';
o_error2='1';
else
o_error1='0';
o_error2='0';
end if;
end freq_meter_arch;
Yes I know there is a lot of errors Here is the timeline. https://www.alteraforum.com/forum/attachment.php?attachmentid=14030
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The syntax errors should be easy enough for you to fix by referencing a vhdl text book.
But there are more fundamental errors - eg. Having a rising edge inside a rising edge will never occur in reality. I suggest you work through a tutorial that covers basic logic to try and understand what is wrong with your code.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
ok.
Tricky, thanks for the advice.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
