gated clock
I have a 100 Mhz clock coming to my FPGA CLOCK100. This goes to the SOPC which has a PLL. The PLL generates a 150 MHz clock CLOCK150 which goes to my custom logic which has a PLL. The output of the PLL has CLOCK150_CUSTOM and lock. I wantuse the clock which is valid only when the PLL has locked.
I want to use locked clock
ie. CLOCK150_CUSTOM_LOCKED = CLOCK150_CUSTOM && lock;
the Design assistant says
Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) related to this rule.
Would you know/suggest how to get around it and suggest any better scheme of doing this.
Can I create a lock signal from the SOPC PLL?
I would typically use the lock output of the PLL to control the reset logic in my design.
Jake
Are you doing your design in HDl (Verilog or VHDL) or schematic?
Jake
The top level is a schematic.
My custom block is in verilog.
One more related question.In my SDC file I define the clock to the input port only (which is input clock to PLL in SOPC). Then I use
derive_pll_clocks to derive other clock.
Do I need to define clock to the 2nd PLL (in my custom logicic) which gets its input from the output of the 1st PLL.
I am getting some timing violations (from the output of the SOPC registers which run off the 1st PLL) to the input registers in custom logic running off 2nd PLL.
