I have a 100 Mhz clock coming to my FPGA CLOCK100. This goes to the SOPC which has a PLL. The PLL generates a 150 MHz clock CLOCK150 which goes to my custom logic which has a PLL. The output of the PLL has CLOCK150_CUSTOM and lock. I wantuse the clock which is valid only when the PLL has locked.
I want to use locked clock ie. CLOCK150_CUSTOM_LOCKED = CLOCK150_CUSTOM && lock; the Design assistant says Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) related to this rule. Would you know/suggest how to get around it and suggest any better scheme of doing this. Can I create a lock signal from the SOPC PLL? Thanks.Link Copied
I would typically use the lock output of the PLL to control the reset logic in my design.
Jake- Mark as New
Are you doing your design in HDl (Verilog or VHDL) or schematic?
Jake- Mark as New
The top level is a schematic.
My custom block is in verilog. One more related question.In my SDC file I define the clock to the input port only (which is input clock to PLL in SOPC). Then I use derive_pll_clocks to derive other clock. Do I need to define clock to the 2nd PLL (in my custom logicic) which gets its input from the output of the 1st PLL. I am getting some timing violations (from the output of the SOPC registers which run off the 1st PLL) to the input registers in custom logic running off 2nd PLL.
