generate a .vqm file
hi,
i am using a Cyclone II FPGA and i want to generate a vqm file by the Quartus II Compiler. When i compile my design , sometimes a ASCII text file is created, and sometimes a binary file. what should i do in order to create a ASCII text file,instead of a binary file?
--- Quote Start ---
hi,
--- Quote End ---
Hi suplina,
choose : Assignments -> Settings -> Compilation Process Settings ->
"Save a node-level netlist of the entire design into a persistent source file"
Quartus will create a new directory "atom_netlist". You will find the vqm file in this
directory.
Kind regards
GPK
--- Quote Start ---
Hi suplina,
directory.
Kind regards
GPK
--- Quote End ---
hi,
Thank you for your answer, i have done what you told me and created two different vqm files for two different modules,however,it is strage that one of the vqm file is full of messy code ,and the other shows normal,why?
--- Quote Start ---
hi,
--- Quote End ---
what kind of modules do you have ? Is one a third party IP block ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
hi,
no,neither of them contains a third party IP block.
--- Quote Start ---
hi,
--- Quote End ---
is it possible that you post the designfile(s) ?
Kind regrads
GPK
--- Quote Start ---
hi,
--- Quote End ---
hi,
Does it matter if i use an ip block called sram_16Bit_512k made by Terasic Technologies inc?
--- Quote Start ---
hi,
--- Quote End ---
I assume that this block is an SRAM-Controller ? That is excatly what mean with an
third party IP block. Did you get the source of the Controller ? If not , I'm pretty sure that a vqm file of this block will be encrypted.
Kind regards
GPK
--- Quote Start ---
Hi suplina,
directory.
Kind regards
GPK
--- Quote End ---
excuse me for jumping in, but what version of Quartus are you using? I'm using 8.1 and I don't see these setting.
--- Quote Start ---
--- Quote End ---
which device are you using ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
I'm using cyclone III (e3c780f120), but I understand why it should matter, we are talking about synthesis stage, not about a device feature. :confused:
--- Quote Start ---
--- Quote End ---
The vqm files are only supported unitl StratixII and CycloneII. The feature is for newer devices disabled. In past vqm files were used e.g. for import of an optimized design into a new project. For newer devices Altera recommends to use the partition flow.
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
hi,
i have understood what you mean,thank you for your help.
