Hi all,
I am using a CycloneIII FPGA. When I compile my design, only a .sof file is created but not a .pof file. What should I configure in order to create a .pof file (for Active Serial Programming)? Thanks, DvidoLink Copied
--- Quote Start --- Hi all, I am using a CycloneIII FPGA. When I compile my design, only a .sof file is created but not a .pof file. What should I configure in order to create a .pof file (for Active Serial Programming)? Thanks, Dvido --- Quote End --- Hi Dvido, you can convert the sof to a pof file. Open Quartus and choose: File -> Convert Programming Files Kind regards GPK
Actually I noticed that it's a part of a bigger problem.
As I understand, these files are supposed to be created by default. Except that, when I compile a design, sometimes the compiler won't give me an error on some basic things, like wrong vector size (things that would always result with a compilation error). I re-installed QuartusII but it didn't help. Any ideas?- Mark as New
Dear Divdo and others
Greetings May I ask for your help, please? I am compiling my design by using Cyclone II. The compilation was successfully done and yet to get .pof and .sof files. Kindly advise me what I should do? Regards nazar- Mark as New
--- Quote Start --- Actually I noticed that it's a part of a bigger problem. As I understand, these files are supposed to be created by default. Except that, when I compile a design, sometimes the compiler won't give me an error on some basic things, like wrong vector size (things that would always result with a compilation error). I re-installed QuartusII but it didn't help. Any ideas? --- Quote End --- Hi Dvido, did Quartus finished succesfully or not ? Maybe you can post an example here ? Kind regards GPK
It did, though it had a problem with one of the files (don't remember which one) so I deleted all the compilation files and re-compiled. Also when I burn it it works fine. I converted the files like you suggested.
I still think that I have a problem since these files aren't generated automatically and the compiler acts a little strange (as I described earlier).- Mark as New
--- Quote Start --- It did, though it had a problem with one of the files (don't remember which one) so I deleted all the compilation files and re-compiled. Also when I burn it it works fine. I converted the files like you suggested. I still think that I have a problem since these files aren't generated automatically and the compiler acts a little strange (as I described earlier). --- Quote End --- Hi, that means all is up and running now? Kind regards GPK
I am able to compile but I still have these strange issues with the .pof files not being created and some errors not being reported by the compiler.
--- Quote Start --- I am able to compile but I still have these strange issues with the .pof files not being created and some errors not being reported by the compiler. --- Quote End --- Ok, when using a pof file you need a configuration device. In the Quartus default settings the generation of prog files for the configuration device is disabled ( I don't know why ??). You can change the setting by: Assignments -> Device -> Device and Pin Options ... -> configuration Switch on "Use Configuration Device" and select your configuration device. For your other problem, can you post an example ? Kind regards GPK
Here is an example of the strange behavior: bellow you can find a very simple process. It didn't work yesterday but its working today, though I haven't changed anything.
handshake : process (rst,gpio14) begin if (rst = '0') then start_handshake_fsm <= '0'; temp_counter <= (others => '0'); elsif (gpio14'event and gpio14 = '1') then if (temp_counter < "1000") then temp_counter <= temp_counter + '1'; start_handshake_fsm <= '0'; elsif (temp_counter = "1000") then temp_counter <= temp_counter; start_handshake_fsm <= '1'; end if; end if; end process handshake;- Mark as New
--- Quote Start --- Here is an example of the strange behavior: bellow you can find a very simple process. It didn't work yesterday but its working today, though I haven't changed anything. handshake : process (rst,gpio14) begin if (rst = '0') then start_handshake_fsm <= '0'; temp_counter <= (others => '0'); elsif (gpio14'event and gpio14 = '1') then if (temp_counter < "1000") then temp_counter <= temp_counter + '1'; start_handshake_fsm <= '0'; elsif (temp_counter = "1000") then temp_counter <= temp_counter; start_handshake_fsm <= '1'; end if; end if; end process handshake; --- Quote End --- Hi, what kind of strange behaviour did you observe ? Do have timing violations in your design ? Where does the gpio14 signal coming from ( xxMhz?) Kind regards GPK
The strange behavior is that it didn't work and then suddenly it started working.
gpio14 is coming from another FPGA with a very low frequency, there shouldn't be any timing issue since I don't use the clock for that process. I ran it now for a few times and it works fine.- Mark as New
--- Quote Start --- The strange behavior is that it didn't work and then suddenly it started working. gpio14 is coming from another FPGA with a very low frequency, there shouldn't be any timing issue since I don't use the clock for that process. I ran it now for a few times and it works fine. --- Quote End --- Hi, but you use the gpio14 as a clock ! (gpio14'event and gpio14 = '1'). If you use signals generated in this block in a block with a different clock your design will not work stable. BTW did you connect yor reset signal ? Kind regards GPK
I use the start_handshake_fsm signal only as a flag for another process. Though the other process uses another clock, it doesn't matter. As I said now its working. I did connect the reset signal. Might be that the FPGA was "stuck" and when I switched the power off for the night it fixed it?- Mark as New
--- Quote Start --- Hi, I use the start_handshake_fsm signal only as a flag for another process. Though the other process uses another clock, it doesn't matter. As I said now its working. I did connect the reset signal. Might be that the FPGA was "stuck" and when I switched the power off for the night it fixed it? --- Quote End --- Hi, how did you synchronize your handshake signal in the other clock domain, in order to prevent metastability ? That could be the reason why your design is stuck . Kind regards GPK
I put an if condition on the other process: if (rising_edge(clk) and start_handshake_fsm = '1') then.... is that a problem?- Mark as New
--- Quote Start --- Hi, I put an if condition on the other process: if (rising_edge(clk) and start_handshake_fsm = '1') then.... is that a problem? --- Quote End --- Hi, this could be a problem. I assume that "clk" is much faster then the gpio signal. In this case you should latch the handshake signal with two registers in a row clocked by "clk". For more info's look: http://www.fpga4fun.com/crossclockdomain1.html Kind regards GPK
