creating .pof file
Hi all,
I am using a CycloneIII FPGA. When I compile my design, only a .sof file is created but not a .pof file. What should I configure in order to create a .pof file (for Active Serial Programming)?
Dvido
--- Quote Start ---
Hi all,
Dvido
--- Quote End ---
Hi Dvido,
you can convert the sof to a pof file. Open Quartus and choose:
File -> Convert Programming Files
Kind regards
GPK
Actually I noticed that it's a part of a bigger problem.
As I understand, these files are supposed to be created by default. Except that, when I compile a design, sometimes the compiler won't give me an error on some basic things, like wrong vector size (things that would always result with a compilation error). I re-installed QuartusII but it didn't help. Any ideas?
Dear Divdo and others
Greetings
May I ask for your help, please? I am compiling my design by using Cyclone II. The compilation was successfully done and yet to get .pof and .sof files. Kindly advise me what I should do?
nazar
--- Quote Start ---
--- Quote End ---
Hi Dvido,
did Quartus finished succesfully or not ? Maybe you can post an example here ?
Kind regards
GPK
It did, though it had a problem with one of the files (don't remember which one) so I deleted all the compilation files and re-compiled. Also when I burn it it works fine. I converted the files like you suggested.
I still think that I have a problem since these files aren't generated automatically and the compiler acts a little strange (as I described earlier).
--- Quote Start ---
--- Quote End ---
that means all is up and running now?
Kind regards
GPK
I am able to compile but I still have these strange issues with the .pof files not being created and some errors not being reported by the compiler.
--- Quote Start ---
--- Quote End ---
Ok,
when using a pof file you need a configuration device. In the Quartus default settings the
generation of prog files for the configuration device is disabled ( I don't know why ??).
You can change the setting by:
Assignments -> Device -> Device and Pin Options ... -> configuration
Switch on "Use Configuration Device" and select your configuration device.
For your other problem, can you post an example ?
Kind regards
GPK
Here is an example of the strange behavior: bellow you can find a very simple process. It didn't work yesterday but its working today, though I haven't changed anything.
handshake : process (rst,gpio14)
begin
if (rst = '0') then
start_handshake_fsm <= '0';
temp_counter <= (others => '0');
elsif (gpio14'event and gpio14 = '1') then
if (temp_counter < "1000") then
temp_counter <= temp_counter + '1';
elsif (temp_counter = "1000") then
temp_counter <= temp_counter;
start_handshake_fsm <= '1';
end if;
end if;
end process handshake;
--- Quote Start ---
begin
if (rst = '0') then
end if;
end if;
--- Quote End ---
what kind of strange behaviour did you observe ? Do have timing violations in your design ? Where does the gpio14 signal coming from ( xxMhz?)
Kind regards
GPK
The strange behavior is that it didn't work and then suddenly it started working.
gpio14 is coming from another FPGA with a very low frequency, there shouldn't be any timing issue since I don't use the clock for that process.
I ran it now for a few times and it works fine.
--- Quote Start ---
--- Quote End ---
but you use the gpio14 as a clock ! (gpio14'event and gpio14 = '1'). If you use signals generated in this block in a block with a different clock
your design will not work stable. BTW did you connect yor reset signal ?
Kind regards
GPK
I use the start_handshake_fsm signal only as a flag for another process. Though the other process uses another clock, it doesn't matter. As I said now its working.
I did connect the reset signal.
Might be that the FPGA was "stuck" and when I switched the power off for the night it fixed it?
--- Quote Start ---
--- Quote End ---
how did you synchronize your handshake signal in the other clock domain, in order to prevent metastability ? That could be the reason why your design is stuck .
Kind regards
GPK
I put an if condition on the other process:
if (rising_edge(clk) and start_handshake_fsm = '1') then....
is that a problem?
--- Quote Start ---
is that a problem?
--- Quote End ---
this could be a problem. I assume that "clk" is much faster then the gpio signal.
In this case you should latch the handshake signal with two registers in a row clocked by "clk". For more info's look:
http://www.fpga4fun.com/crossclockdomain1.html
Kind regards
GPK
