generate *.pin file
Hello everyone, Do you know how to generate *.pin file for my FPGA from Quartus II? This *.pin file will contain all pin assignments and also the voltage of each bank.
The format of this file is like the below:
--------------------------------------------------------------------------------- -- Pin directions (input, output or bidir) are based on device operating in user mode. --------------------------------------------------------------------------------- Quartus II 64-Bit Version 14.1.0 Build 186 12/03/2014 SJ Full Version CHIP "dpinput" ASSIGNED TO AN: 5AGXBA3D4F31C4 Device Migration List: "5AGXBA5D4F31C4, 5AGXBA7D4F31C4" Pin Name/Usage : Location : Dir. : I/O Standard : Voltage : I/O Bank : User Assignment ------------------------------------------------------------------------------------------------------------- NC : A2 : : : : : NC : A3 : : : : : dp2_select_led : A4 : output : 3.3-V LVTTL : : 7A : Y dp2_sync_led : A5 : output : 3.3-V LVTTL : : 7A : Y RESERVED_INPUT_WITH_WEAK_PULLUP : A6 : : : : 7A : NC : A7 : : : : : NC : A8 : : : : : VCCIO7B : A9 : power : : 1.5V : 7B : dp2_aux_tx : A10 : output : 1.5 V : : 7B : Y dp2_aux_rx : A11 : input : 1.5 V : : 7B : Y VCCIO7C : A12 : power : : 2.5V : 7C : RESERVED_INPUT_WITH_WEAK_PULLUP : A13 : : : : 7C : dp2_hpd_snk : A14 : output : 2.5 V : : 7C : Y RESERVED_INPUT_WITH_WEAK_PULLUP : A15 : : : : 7C : RESERVED_INPUT_WITH_WEAK_PULLUP : A16 : : : : 7D : RESERVED_INPUT_WITH_WEAK_PULLUP : A17 : : : : 7D : VCCIO7D : A18 : power : : 2.5V : 7D :
It should be one of the outputfiles after generating the design.
Should be generated by the Fitter...
--- Quote Start ---
--- Quote End ---
I believe what you are asking is how to automate the pin assignments, so that you do not have to repeat it.
The solution is to use a Tcl script with the pin assignments. Take the design that you used to generate the *.pin file above (i.e., that file was generated when you synthesized that design). In the Quartus GUI select "Project->Generate Tcl file for Project" and look at the generated file. Inside that file you will see the Tcl statements that implement the pin assignments, and a lot more Tcl functions that setup the design.
Now, go and take a look at a few of the example designs I have posted, eg.,
Post#2
http://www.alteraforum.com/forum/showthread.php?t=45927
Post#20
http://www.alteraforum.com/forum/showthread.php?t=45748&page=2
Perform the steps in the readme.txt file, then use "Project->Generate Tcl file for Project" to generate a Tcl file, then go and take a look at constraints.tcl and synth.tcl. constraints.tcl contains the pin assignments and is reusable for any design that uses this board. synth.tcl is specific to a project and sets up the Quartus GUI.
Cheers,
Dave
Hi Dave, Thanks for your detailed reply. Learnt a lot!
