i m learning the Introduction to the Altera SOPC Builder Using VHDL Design
working on led display with switches example. i followed every step as per instruction.i type the lights.vhd but at the time of compilation i m getting error like Error (10500): VHDL syntax error at nios_system_inst.vhd(13) near text "nios_system_ins"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" please tell me where is the problemLink Copied
did you put any spaces in component names?
Could you open nios_system_inst.vhd and show us the lines around 13?- Mark as New
sorry that is line 2.
the error is nios_system_inst : nios_system port map( out_port_from_the_LEDs => out_port_from_the_LEDs, clk_0 => clk_0, in_port_to_the_Switches => in_port_to_the_Switches, reset_n => reset_n ); --- Quote Start --- did you put any spaces in component names? Could you open nios_system_inst.vhd and show us the lines around 13? --- Quote End ---- Mark as New
Oh... is it the _inst file generated by sopc builder? In that case this is just an example of how the SOPC design can be instantiated in a project. You need to copy-paste its contents to your top-level vhdl file.
yes _inst file isgenerated by sopc builder it is a example.
but again i m getting error please inform exactly what to do. --- Quote Start --- Oh... is it the _inst file generated by sopc builder? In that case this is just an example of how the SOPC design can be instantiated in a project. You need to copy-paste its contents to your top-level vhdl file. --- Quote End ---- Mark as New
LIBRARY ieee;
USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.std_logic_unsigned.all; ENTITY lights IS PORT ( SW : IN STD_LOGIC_VECTOR(7 DOWNTO 0); KEY : IN STD_LOGIC_VECTOR(0 DOWNTO 0); CLOCK_50 : IN STD_LOGIC; LEDG : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) ); END lights; ARCHITECTURE Structure OF lights IS COMPONENT nios_system PORT ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; out_port_from_the_LEDs : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); in_port_to_the_Switches : IN STD_LOGIC_VECTOR (7 DOWNTO 0) ); END COMPONENT; BEGIN -- Instantiate the Nios II system entity generated by the SOPC Builder nios_system_inst : nios_system port map( out_port_from_the_LEDs => LEDG, clk => CLOCK_50, in_port_to_the_switches => SW, reset_n => KEY(0) ); END Structure; this is the top level code but getting error --- Quote Start --- Oh... is it the _inst file generated by sopc builder? In that case this is just an example of how the SOPC design can be instantiated in a project. You need to copy-paste its contents to your top-level vhdl file. --- Quote End ---- Mark as New
Is the error message still on the nios_system_inst.vhd file? If yes you should remove it from your project and put the top level VHDL instead.
yes there it self
I am also getting the same error.i removed the nios_inst.vhd file from the project. and kept the top level entity file. here problem is i dont know how to instantiate the sopc system generated file into top level entity . please help. i am also doing the same LED example. here i am uploading that file and SOPC generated files.
this is the system generated file , i am getting error here(underlined). --Example instantiation for system 'nios_system'
port map(
clk_0 => clk_0,
reset_n => reset_n
I have the similar problem. I am doing the tutorial "Using the SDRAM on Altera’s DE2-115 Board with VHDL Designs" which have SOPC builder to generate VHDL file. In top level entity light, there is already SOPC generated nios system is defined and instantiated as: ARCHITECTURE Structure OF lights IS COMPONENT nios_system PORT ( clk_0 : IN STD_LOGIC; reset_n : IN STD_LOGIC; out_port_from_the_LEDs : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); in_port_to_the_Switches : IN STD_LOGIC_VECTOR(7 DOWNTO 0); zs_addr_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(12 DOWNTO 0); zs_ba_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(1 DOWNTO 0); zs_cas_n_from_the_sdram_0 : OUT STD_LOGIC; zs_cke_from_the_sdram_0 : OUT STD_LOGIC; zs_cs_n_from_the_sdram_0 : OUT STD_LOGIC; zs_dq_to_and_from_the_sdram_0 : INOUT STD_LOGIC_VECTOR(31 DOWNTO 0); zs_dqm_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); zs_ras_n_from_the_sdram_0 : OUT STD_LOGIC; zs_we_n_from_the_sdram_0 : OUT STD_LOGIC); END COMPONENT; BEGIN --¡¡ Instantiate the Nios II system entity generated by the SOPC Builder. NiosII: nios_system PORT MAP ( clk_0 => CLOCK_50, reset_n => KEY(0), out_port_from_the_LEDs => LEDG, in_port_to_the_Switches => SW, zs_addr_from_the_sdram_0 => DRAM_ADDR, zs_ba_from_the_sdram_0 => DRAM_BA, zs_cas_n_from_the_sdram_0 => DRAM_CAS_N, zs_cke_from_the_sdram_0 => DRAM_CKE, zs_cs_n_from_the_sdram_0 => DRAM_CS_N, zs_dq_to_and_from_the_sdram_0 => DRAM_DQ, zs_dqm_from_the_sdram_0 => DRAM_DQM, zs_ras_n_from_the_sdram_0 => DRAM_RAS_N, zs_we_n_from_the_sdram_0 => DRAM_WE_N ); DRAM_CLK <= CLOCK_50; END Structure; Then why again separate file is generated without entity and component as: --Example instantiation for system 'nios_system' nios_system_inst : nios_system port map( out_port_from_the_LEDs => out_port_from_the_LEDs, zs_addr_from_the_sdram_0 => zs_addr_from_the_sdram_0, zs_ba_from_the_sdram_0 => zs_ba_from_the_sdram_0, zs_cas_n_from_the_sdram_0 => zs_cas_n_from_the_sdram_0, zs_cke_from_the_sdram_0 => zs_cke_from_the_sdram_0, zs_cs_n_from_the_sdram_0 => zs_cs_n_from_the_sdram_0, zs_dq_to_and_from_the_sdram_0 => zs_dq_to_and_from_the_sdram_0, zs_dqm_from_the_sdram_0 => zs_dqm_from_the_sdram_0, zs_ras_n_from_the_sdram_0 => zs_ras_n_from_the_sdram_0, zs_we_n_from_the_sdram_0 => zs_we_n_from_the_sdram_0, clk_0 => clk_0, in_port_to_the_Switches => in_port_to_the_Switches, reset_n => reset_n ); and upon compilation giving following error: Error (10500): VHDL syntax error at nios_system_inst.vhd(2) near text "nios_system_inst"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" When I remove this additional file, the compilation is successful but I am afraid of loading on FPGA concerning it may damage with incomplete/wrong program. Any suggestion? Thanks in advance- Mark as New
The nios_system_inst.vhd file is just generated by SOPC builder to give you an example of how you can instantiate your project in a VHDL file. You are supposed to copy/paste the contents of that file in your top level design, but in your case it is already there. The *_inst.vhd files should never be included in your project as a file to compile directly.
Just remove it and it will be fine.- Mark as New
TO_BE_DONE
It is possible that the clock signal has a different name in nios_system.qip. Could you check in the generated nios_system_inst.vhd file?
Well, that did the trick.
Instead of clk, the generated nios_system_inst.vhd has clk_0. Thank you very much. Now, the next step would be using nios II.
