17255 Discussions
getting error in digiclock project..help me..
hii.
i am doing project on altera de1 board on digi clock.
when i compile the program i am getting error in the following line (c1: sec_clk port map(clkm,rstsec,sflag);
it shows node c1 instantiates undefined entity'sec_clk'
pls help me..
thanks.
code is given below:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity DigiClock is
port(
clkm: in std_logic;
rst,setm,seth: in std_logic;
z: in std_logic;
op: out std_logic;
op0,op1,op2,op3: out std_logic_vector(6 downto 0)
end DigiClock;
architecture clock of DigiClock is
component sec_clk
Port (
clks : in std_logic;
rsts : in std_logic;
ops : out std_logic
end component;
component min_clk
Port (
clkmi : in std_logic;
rst : in std_logic;
opm : out std_logic
end component;
component manu_clk
Port (
set : in std_logic;
clk : in std_logic;
opu : out std_logic
end component;
component seg7
port(m: in integer range 0 to 10;
num: out std_logic_vector(6 downto 0));
end component;
signal mflag: std_logic;
signal sflag: std_logic;
signal a: integer range 0 to 10;
signal b: integer range 0 to 6;
signal c: integer range 0 to 10;
signal d: integer range 0 to 3;
signal x: std_logic;
signal hrt: std_logic;
signal t: std_logic;
signal u: std_logic;
signal v: std_logic;
signal rstsec: std_logic;
signal mi: std_logic;
signal hr: std_logic;
begin
c2: min_clk port map(sflag,rst,mflag);
c3: manu_clk port map(setm,clkm,mi);
c4: manu_clk port map(seth,clkm,hr);
op<=sflag;
delayt: process(clkm,z)
begin
if rising_edge(clkm) then
t<= z;
end if;
end process delayt;
clockmin: process(x,rst,u)
variable m0: integer range 0 to 10:=0;
variable m1: integer range 0 to 6:=0;
begin
a<=m0;
b<=m1;
hrt<= '1' and u;
if rst='0' then
m0:=0;
m1:=0;
elsif falling_edge(x) then
if m0/=9 then
m0:= m0+1;
u<='0';
elsif m0=9 and m1/=5 then
m0:=0;
m1:= m1+1;
u<='0';
elsif m0=9 and m1=5 then
m0:=0;
m1:=0;
u<='1';
end if;
end if;
end process clockmin;
selecter: process(t,hr,mi,mflag,hrt)
begin
if t = '0' then
x<=mi;
v<=hr;
rstsec<='0';
else
x<=mflag;
v<=hrt;
rstsec<='1';
end if;
end process selecter;
clockhr: process(v,rst)
variable m2: integer range 0 to 10:=2;
variable m3: integer range 0 to 3:=1;
begin
c<=m2;
d<=m3;
if rst = '0' then
m2:=2;
m3:=1;
elsif rising_edge(v) then
if m2/=9 and m3=0 then
m2:=m2+1;
elsif m2=9 and m3=0 then
m2:=0;
m3:=m3+1;
elsif m2/=2 and m3=1 then
m2:=m2+1;
elsif m2=2 and m3=1 then
m2:=1;
m3:=0;
end if;
end if;
end process clockhr;
z0: seg7 port map(a,op0);
z1: seg7 port map(b,op1);
z2: seg7 port map(c,op2);
z3: seg7 port map(d,op3);
end clock;
sounds like neither the project directory itself nor the "project files" definition include the instantiated (Sub)modules instantiated by Component xyz. Thus the compiler cannot "open" these modules for compilation...
