getting error
i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach
Without the error messages themselves it will be difficult to help you...
They all compile fine for me.
--- Quote Start ---
--- Quote End ---
which device ? Which Quartus Version ? What kind of error message ?
It runs in my environment. I only got a warning regarding the net "hcount" which is not used in the design.
Kind regards
GPK
my top entity is pots.vhd the error are like this
Error: Port "clk27_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_data_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_hs_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_vs_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "vga_b_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_blank_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_clk_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_g_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_hs_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_r_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_sync_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_vs_from_the_vga" does not exist in macrofunction "nios"
cyclone ii-v-9sp2
i have another vhdl code for the frame buffer
--- Quote Start ---
--- Quote End ---
The error messages indicates that your NIOS system did not have the listed ports.
BTW: Your posted source code is not complete !
Kind regards
GPK
