getting error
名誉分销商 II
1,930 次查看
i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach
0 项奖励
7 回复数
名誉分销商 II
1,095 次查看
Without the error messages themselves it will be difficult to help you...
0 项奖励
名誉分销商 II
1,095 次查看
They all compile fine for me.
0 项奖励
名誉分销商 II
1,095 次查看
--- Quote Start ---
--- Quote End ---
which device ? Which Quartus Version ? What kind of error message ?
It runs in my environment. I only got a warning regarding the net "hcount" which is not used in the design.
Kind regards
GPK
0 项奖励
名誉分销商 II
1,095 次查看
my top entity is pots.vhd the error are like this
Error: Port "clk27_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_data_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_hs_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "td_vs_to_the_tv_in" does not exist in macrofunction "nios"
Error: Port "vga_b_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_blank_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_clk_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_g_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_hs_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_r_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_sync_from_the_vga" does not exist in macrofunction "nios"
Error: Port "vga_vs_from_the_vga" does not exist in macrofunction "nios"
0 项奖励
名誉分销商 II
1,095 次查看
cyclone ii-v-9sp2
0 项奖励
名誉分销商 II
1,095 次查看
i have another vhdl code for the frame buffer
0 项奖励
名誉分销商 II
1,095 次查看
--- Quote Start ---
--- Quote End ---
The error messages indicates that your NIOS system did not have the listed ports.
BTW: Your posted source code is not complete !
Kind regards
GPK
0 项奖励
回复
