- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach
Ссылка скопирована
7 Ответы
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Without the error messages themselves it will be difficult to help you...
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
They all compile fine for me.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
--- Quote Start --- i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach --- Quote End --- Hi, which device ? Which Quartus Version ? What kind of error message ? It runs in my environment. I only got a warning regarding the net "hcount" which is not used in the design. Kind regards GPK
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
my top entity is pots.vhd the error are like this
Error: Port "clk27_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_data_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_hs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_vs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "vga_b_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_blank_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_clk_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_g_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_hs_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_r_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_sync_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_vs_from_the_vga" does not exist in macrofunction "nios"- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
cyclone ii-v-9sp2
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
--- Quote Start --- i have another vhdl code for the frame buffer --- Quote End --- The error messages indicates that your NIOS system did not have the listed ports. BTW: Your posted source code is not complete ! Kind regards GPK
Ответить
Параметры темы
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
