i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach
Without the error messages themselves it will be difficult to help you...
They all compile fine for me.
--- Quote Start --- i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach --- Quote End --- Hi, which device ? Which Quartus Version ? What kind of error message ? It runs in my environment. I only got a warning regarding the net "hcount" which is not used in the design. Kind regards GPK
my top entity is pots.vhd the error are like this
Error: Port "clk27_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_data_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_hs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_vs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "vga_b_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_blank_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_clk_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_g_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_hs_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_r_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_sync_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_vs_from_the_vga" does not exist in macrofunction "nios"- Mark as New
cyclone ii-v-9sp2
--- Quote Start --- i have another vhdl code for the frame buffer --- Quote End --- The error messages indicates that your NIOS system did not have the listed ports. BTW: Your posted source code is not complete ! Kind regards GPK
