17268 Discussions
half-band filter implementation
I know this is typical in signal processing implementation. Therefore, is there already an example on how to implementation a half-band filter in Verilog? Thanks in advance.
What's wrong with the answer Google would have given you ... ?
http://www.dsprelated.com/showarticle/124.php
Sure its for Xilinx, but you can figure out the differences ...
Is there a corresponding function from Altera for "DDC_HF2_DSP" in the following code for xilinx?
//* (A+D)*B+C
//14 pipelines
genvar Num;
generate
for (Num = 0; Num <= 11; Num = Num + 1)
begin : U_DDC_HF2_DSP
DDC_HF2_DSP DDC_HF2_DSP
//* Inputs
.clk ( Clk ),
.a ( Add_a[Num] ),
.d ( Add_d[Num] ),
.b ( Mult_b[Num] ),
.c ( Add_c[Num] ),
//* Outputs
.p ( Dsp_r[Num] )
end
endgenerate
--- Quote Start ---
//* (A+D)*B+C
//14 pipelines
genvar Num;
generate
//* Inputs
.clk ( Clk ),
.a ( Add_a[Num] ),
.d ( Add_d[Num] ),
.b ( Mult_b[Num] ),
.c ( Add_c[Num] ),
//* Outputs
.p ( Dsp_r[Num] )
end
endgenerate
--- Quote End ---
That is just xilinx mult add (a bit more configurable than altera).
In principle you need to multiply and add input stages with coeffs(sum of products). You can use direct structure or transposed.
For halfband single rate with coeffs 1~11 :
multiply coeffs(1,3,5,6,7,9,11) with their input stages and add up to get (y1)
and so on
as such you need 7 mults
coeff 6 if 2^n then just insert leading n zeros, thus you need 6 mults only
implementation is based on a pipe of 11 stages with mults connected every other coeff then all results added and truncated back. That is all.
since this filter is symmetrical you can also pre add two stages and multiply by its coeff thus you can reduce mults to 3
