17255 Discussions
header file in verilog / a better way to define global constants
Hello, I am working on a verilog project and I need to use some constants parameters in almost all of my modules. So, instead of defining them for every module, I was thinking it makes more sense to have a separate file with all the parameters and constants and include it in each module. However, I am not sure how I can do that. I tried defining them (i.e. defies.v) in a separate file and including it in my module (just like header in C/C++) with `include "defines.v". However compiler is not accepting that and I think, I am doing something wrong.
I would appreciate any suggestion in this regard.
That is the correct way.
You may be doing something wrong..
Showing the syntax error message would help.
If you can use SystemVerilog, the putting them in a package is the way to go.
Thanks for the input. I am kinda swamped with some other projects now. I will definitely look into it. I might be doing something wrong.
Keep in mind that if your header file is just a collection of constants it is not a compile-able unit. For example, if defines.v is:
localparam FOO = 6; localparam BAR = "BAR";
This code needs to be scoped inside a module. So, if you are passing defines.v in a list of files to your compiler, that is your problem. Instead, you'll need to add the path to defines.v in your Verilog include path.
As an aside, I (and at least a few other people I've seen online) use .vh as the file extension for Verilog files which will be `included. This allows you to see which files define modules and which files define constants, functions, etc. Also, some tools will search a given path for files to compile based on module instantiation. This convention prevents such modes of operation from stumbling on code which can't be compiled on its own.
