17268 Discussions
help!!! A simple question of a verilog fresh man
i have typed the following codes into" .v file"
but after compiled , the compiler showed me:" Error: Can't synthesize current design -- Top partition does not contain any logic"
but i have make it the top level through "Project->Set top_level Entity "
it still can't be solved ~~please help :p
codes:
module myand(a, b, c);
// Input Port(s)
input a,b;
// Output Port(s)
output c;
assign c=a&b;
// Additional Module Item(s)
endmodule
please help me ,I really can't solve it
--- Quote Start ---
--- Quote End ---
check whether your toplevel is set to to "myand". have look to the attahed project.
kind regards
GPK
thank you ,i will try it ~:)
--- Quote Start ---
kind regards
GPK
--- Quote End ---
