17255 Discussions
help in sintax for various inputs to single internal signal vector binary and decimal
hello,,, i have a problem,,
i need read 8 inputs from a digital encoder position d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic, each with (0 or 1 state). but my problem is convert these inputs to a single signal : std_logic_vector(7 downto 0) in a internal signal in the (binary) in the order MSB is d8. then after this vector created to other single output (deci : out std_logic) in one data in decimal, of 0 to 255 Which is its equivalent.
any idea that help me in a simple code sintax
--- Quote Start ---
--- Quote End ---
Internal_signal <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1;
this concatenation, and it has no cost on resource.
--- Quote Start ---
--- Quote End ---
Ok thank you and convert this vector of 8 bits to decimal?
--- Quote Start ---
--- Quote End ---
dout <= to_integer(signed(interna_data));
it needs library numeric_std
--- Quote Start ---
--- Quote End ---
ok,, in my code when compile, generate multiple output pins, not a single pin "deci" why?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity joystick is
port
d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic;
deci : out integer range 0 to 255) ;
end joystick;
architecture lectura of joystick is
signal val_bin : std_logic_vector(7 downto 0);
begin
val_bin <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1;
deci <= to_integer(signed(val_bin));
end lectura;
i can save this output in one only value for send these after data to a serial COM for using in a program in PC? my code generate various output pins.
Ultimately, your integer deci will have 8 bits, and hence 8 output pins.
If you need to send it to a PC over Serial (RS232 I assume) you will need to serialise these bits - ie. send one at a time. RS232 has a protocol you must follow - and there are many examples out there on the internet.
Thank you, i decide my data, leave it in one internal signal of 8 bits, now read about UART examples.
library ieee;
entity joystick is
port
(d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic);
--deci : out integer range 0 to 255
end joystick;
signal deci : integer range 0 to 255;
begin
deci <= to_integer(unsigned(val_bin));
end lectura;
