17261 Discussions
how to design Filters using verilog and nios? like butterworth, high and low pass etc
Dear sir,
I am Mtech final year student. Right now I am working on ac energy parameter monitoring system. In my project I want to design filters for noise reduction like low pass , high pass , butterwort, chebysev etc... so can u plz suggest me how to make filter in fpga using Verilog. Step for implementing , any notes, materials etc....
Basically what you need is rather to calculate the filter parameters and normalize them for integers. Or that is what I have done in the past. Filters are basically additions of different "volumes" over a length of time. The Code itself is not the hard part. But what I tend to do for simple filters is to simulate an ordinary RC filter like this out<=out+(k*(in-out)/256) ... K being 0-256 here.. this also works with resonance and feedback if you limit the signals and what not. Interpolation uses the same formula but with different inputs/outputs.
THis is a piece of PROTOTYPE CODE i used for a synth project.. i ended up not using it .. And for GOD SAKES keep in mind I'm a total beginner at this ... but at least it's something ,right..
reg signed yaudio ; //yaudio is output from filters (audioout is input) reg signed ac; //accumulator always @ (posedge clk30) begin reg signed b0=68; //lowpass filter response reg signed b1=16; reg signed b2=68; //(or 76) ,b2 is most often same as b0(could be optimized) reg signed a1=117; reg signed a2=-54; reg signed in; reg signed wa,wb,wc; reg l; //timer limit value reg co; //the actual timers reg signed m; //feedback level multiplier reg ch; l<=(potlim/32);//frequency cutoff m<=(potlim/256);//resonance level ch<=ch+1; //8channels, clock through them all in = ((audioout+(audioout*m)/32)-((yaudio*m)/8))*4; //do feedback and input wa = ((wc * a2) + (wb * a1) + (in /2))/64; //do filtering ac = (wa * b0) + (wb * b1) + (wc * b2); //do more filtering if (co++>=l) begin co=0; wc <= wb; wb <= wa; end //rotate data for filter if (co++>=l) begin co=0; wc <= wb; wb <= wa; end //faster = higher cutoff if (co++>=l) begin co=0; wc <= wb; wb <= wa; end //at different speeds if (co++>=l) begin co=0; wc <= wb; wb <= wa; end if (co++>=l) begin co=0; wc <= wb; wb <= wa; end if (co++>=l) begin co=0; wc <= wb; wb <= wa; end if (co++>=l) begin co=0; wc <= wb; wb <= wa; end if (co++>=l) begin co=0; wc <= wb; wb <= wa; end end assign yaudio = ac/256/2; //do output levelchange assign yaudio = ac/256/2; //to be able to use all bits assign yaudio = ac/256/2; //input also does this assign yaudio = ac/256/2; //and center too assign yaudio = ac/256/2; assign yaudio = ac/256/2; assign yaudio = ac/256/2; assign yaudio = ac/256/2;
This is a piece of PROTOTYPE CODE i used for a synth project.. i ended up not using it .. And for GOD SAKES keep in mind I'm a total beginner at this ... but at least it's something ,right..
