17259 Discussions
Quartus Prime Standard Edition v17.0 Error: add_fileset_file: No such file
I'm facing error in Qsys while generating NIOS system with "create simulation model" = either verilog or vhdl, no error if "create simulation model" = NONE.
Does anyone know what is causing this error?
https://alteraforum.com/forum/attachment.php?attachmentid=14441&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14442&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14443&stc=1
Error: add_fileset_file: No such file /tmp/alt7491_7829365739350634514.dir/0006_cpu_gen/simgen_tmp_0
while executing
"add_fileset_file "$file_name" OTHER PATH "$my_file""
(procedure "sub_add_generated_files" line 51)
invoked from within
"sub_add_generated_files "$NAME" "$output_directory" "$rtl_ext" "$simgen" "$plainTEXTfound""
(procedure "generate_with_plaintext" line 6)
invoked from within
"generate_with_plaintext "$NAME" "$rtl_ext" "$simgen""
(procedure "sub_sim_verilog" line 5)
invoked from within
"sub_sim_verilog nios_nios2_gen2_0_cpu"
Error: Generation stopped, 33 or more modules remaining
Error: qsys-generate failed with exit code 1: 2 Errors, 0 Warnings
Are you using the fast version of the processor? Do you have a license for the fast version?
--- Quote Start ---
--- Quote End ---
yes, I'm using NIOS II/f, Qsys is able to generate synthesis files but not simulation files, seems not license issue.
And Qsys Pro can generate both the simulation and synthesis files.
Can you try following.
1. Try generating the testbench for same project and see if you face similar Error ?
Qsys menu
Generate > Generate Testbench System
2. Use the NIOs system from AN351 and see if you can generate the simulation file
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-simulating-niosii.html
3. Also try newer version of Quartus Prime 17.1 ?
arslanusman2003
(This message was posted on behalf of Intel Corporation)
1. I tried "Generate Testbench System", as long as "Create Simulation Model" is Verilog or VHDL, generation failed.
2. Same failure.
3. It will take some time to install 17.1, I have tried v16 with same error. Quartus II v13.1 has no issue.
Hi Terry,
It is working fine with Quartus prime Standard Edition.
Recheck steps and license. OR reinstall the quartus.
Refer attached image in word document
Anand Raj Shankar
Hi Anand,
I will try v17.1 and get back.
Thanks for your support.
