17267 讨论
Quartus Prime Standard Edition v17.0 Error: add_fileset_file: No such file
名誉分销商 II
3,076 次查看
I'm facing error in Qsys while generating NIOS system with "create simulation model" = either verilog or vhdl, no error if "create simulation model" = NONE.
Does anyone know what is causing this error?
https://alteraforum.com/forum/attachment.php?attachmentid=14441&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14442&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14443&stc=1
Error: add_fileset_file: No such file /tmp/alt7491_7829365739350634514.dir/0006_cpu_gen/simgen_tmp_0
while executing
"add_fileset_file "$file_name" OTHER PATH "$my_file""
(procedure "sub_add_generated_files" line 51)
invoked from within
"sub_add_generated_files "$NAME" "$output_directory" "$rtl_ext" "$simgen" "$plainTEXTfound""
(procedure "generate_with_plaintext" line 6)
invoked from within
"generate_with_plaintext "$NAME" "$rtl_ext" "$simgen""
(procedure "sub_sim_verilog" line 5)
invoked from within
"sub_sim_verilog nios_nios2_gen2_0_cpu"
Error: Generation stopped, 33 or more modules remaining
Error: qsys-generate failed with exit code 1: 2 Errors, 0 Warnings
0 项奖励
6 回复数
名誉分销商 II
2,181 次查看
Are you using the fast version of the processor? Do you have a license for the fast version?
0 项奖励
名誉分销商 II
2,181 次查看
--- Quote Start ---
--- Quote End ---
yes, I'm using NIOS II/f, Qsys is able to generate synthesis files but not simulation files, seems not license issue.
And Qsys Pro can generate both the simulation and synthesis files.
0 项奖励
名誉分销商 II
2,181 次查看
Can you try following.
1. Try generating the testbench for same project and see if you face similar Error ?
Qsys menu
Generate > Generate Testbench System
2. Use the NIOs system from AN351 and see if you can generate the simulation file
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-simulating-niosii.html
3. Also try newer version of Quartus Prime 17.1 ?
arslanusman2003
(This message was posted on behalf of Intel Corporation)
0 项奖励
名誉分销商 II
2,181 次查看
1. I tried "Generate Testbench System", as long as "Create Simulation Model" is Verilog or VHDL, generation failed.
2. Same failure.
3. It will take some time to install 17.1, I have tried v16 with same error. Quartus II v13.1 has no issue.
0 项奖励
名誉分销商 II
2,181 次查看
Hi Terry,
It is working fine with Quartus prime Standard Edition.
Recheck steps and license. OR reinstall the quartus.
Refer attached image in word document
Anand Raj Shankar
0 项奖励
名誉分销商 II
2,181 次查看
Hi Anand,
I will try v17.1 and get back.
Thanks for your support.
0 项奖励
回复
