17267 Discussions
how to pass a file name in a generate loop
I need to instantiate the same module many times, so I'm using a for-generate loop. Each time, however, I've to pass to the module a different file name as a GENERIC to initialize a rom inside the module.
The file name is function of the i parameter in the generate loop ... so I wrote this code in quartus (vhdl 2008) but I get errors ... can you help to write it in the right way ?
ENGINES : -- engine instantiation
for i in 0 to ENGINES_NUMBER-1 generate
variable mystringnumber: string (1 to 4);
variable romfile: string (1 to 30);
begin
mystringnumber := (to_string(i));
romfile := ("./roms/weight_lay0_engine" & mystringnumber & ".hex");
ENGINE_inst : entity work.engine
GENERIC MAP (ENGINE_WEIGHT_FILE => romfile)
PORT MAP
(CLOCK => CLOCK,
RESET => RESET,
HITDATA => HITDATA,
ACC => ACC_ENG(i),
INTER_X => ENGINE1_INTER_X,
INTER_Y => ENGINE1_INTER_Y);
end generate ENGINES;
thanks
franco
the string values need to be a constant. So you need to decalre romfile as such. The bast way would be:
constant romfile : string := "./roms/weight_lay0_engine" & integer'image(i) & ".hex";
and put this before the begin like you have done with the variables; you cannot put variables where you have them - you can only use variables inside processes, functions and procedures. You dont need to declare the length of the string because it's implicitly declared with the length of the declaration.
You could use the to_string function instead of integer'image, but Quartus doesnt support them yet (but modelsim does).
Hi tricky thanks a lot, it works perfectly
thanks again
franco
