17257 Discussions
reading integer values representing an image from file
hii..
i'm trying to read ".txt" file representing an image, contains integer value like that..
0 0 0 0 23 163 145 149 154 154 154 155 155 156 156 156 158 158 158 158 158 158 158 ......150 149 149 148 148 148 148 151 143 139 140 102 0 0
0 0 0 0 23 162 145 149 154 154 154 155 155 156 156 156 158 158 158 158 158 158 158 ......150 149 149 148 148 148 148 151 143 139 140 102 0 0
0 0 0 0 0 158 136 128 141 141 141 141 141 141 141 142 144 144 144 144 144 144 144 .......140 140 140 140 140 140 143 139 125 141 129 106 0 0
0 0 0 0 0 143 136 134 136 136 136 136 136 136 136 138 142 142 142 142 142 142 142 .......140 140 140 140 140 140 140 140 130 141 129 104 0 0
0 0 0 0 0 147 139 126 140 140 140 140 140 140 140 141 141 141 141 141 141 141 141 .......140 140 140 140 140 140 141 143 136 134 127 102 0 0
0 0 0 0 0 148 132 134 140 140 140 140 140 140 140 141 138 138 138 138 138 138 138 .......135 135 135 135 135 135 129 135 135 132 133 106 0 0
0 0 0 0 0 143 113 137 141 141 141 141 141 141 141 142 145 145 145 145 145 145 145 .......137 137 137 137 137 137 136 139 136 128 130 102 0 0
0 0 0 0 0 149 118 123 137 137 137 137 137 137 137 139 145 145 145 145 145 145 145 .......132 132 132 132 132 132 123 130 129 126 126 94 0 0
0 0 0 0 14 129 129 123 136 136 136 136 136 136 136 138 139 139 139 139 139 139 139 .......0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ....... 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
but whenever i start simulation i got this warning : )TEXTIO procedure READ(INTEGER) : Parameter L designates an empty string)
hence it is not the estimated output
i thought i was getting this warning since the entire data is integer and i'm declaring my file like this
(file testing_read: text open read_mode is "abc.txt" )
so i changed it to be like that
type integer_file is file of integer;
file testing_read: integer_file open read_mode is "abc.txt";
after which i got this error when compiling: (No feasible entries for subprogram "READLINE".)
I would be so happy for your reply..
thanks,
Niveen..
You cant use readline with a file of type integer, because its only defined for text files. And you woudnt want to do that anyway, because a file of integers is not a text file but a data file, so there is no "line" to speak of.
Anyway, you havent shown your code that reads from the text file. The problem will be your code, not the data file.
so should i change file extension to .dat instead of .txt or what??
here is my process
if (rising_edge(clk)) then
if rst = '1' then
eog_sig <= '0';
else--rst
while (col_s < starting_line_col) loop
if(NOT(endfile(testing_read))) then
READLINE(testing_read, my_line_read);
else
eog_sig <= '1';
end if;
col_s := col_s + 1;
end loop;
col_e := col_s;
while col_e < (ending_line_col+1) loop
READ(my_line_read, s);
end if;
while (row_s < starting_line_row) loop
row_s := row_s + 1;
end loop;--row_s < starting_line_row
row_e := row_s;
row_s := 1;
while row_e < (ending_line_row+1) loop
row_e := row_e + 1;
x := x+s;
i := i+1;
end loop;
col_e := col_e + 1;
end loop;
results := x/i;
x := 0;
i := 1;
resultd_out <= To_StdLogicVector(results,N) ;
col_s := 1;
col_e := 1;
row_s := 1;
row_e := 1;
end if;--rst
end if;--clk
Note:
starting_line_col, starting_line_row, ending_line_col, ending_line_row are input integer values representing a rectangular area of x,y,width,height from which i select certain area to calculate its avarage
sorry for my lazy code..
execuse me cause i'm totally new in that field..
willing to write smart code next time...
thanks for your patiance..
Niveen
renaming it .dat wont make a difference - it will still be a text file. You would have to regenerate the file writing the values direct to 32 bits rather than text values.
The error is becuase you have read in an empty line, or you're trying to read past the end of a line. are you sure you have all the dimensions correct?
actually, its even simpler than that. You're reading the entire file in a single clock cycle. so on the next clock, you've got an empty file. you need to read 1 value per clock cycle, not all of them!
Thanks alot.. i got your point.. :)
i'm having one more question -->can i restart reading the same file in the same clock cycle...
Niveen..
yes you can. use the procedures:
FILE_CLOSE(my_file);
FILE_OPEN(my_file);
thanks Tricky sooo much
i wrote --> FILE_OPEN(testing_read);
befor --> if(NOT(endfile(testing_read)))
and FILE_CLOSE(testing_read); at the end
but i got this error (No feasible entries for subprogram "file_open".)
i want to finish reading the file every clk thats why i'm using a while loop and in the next clock the input values change so i want to re-read the same file again with the new rectangular area...
what should i do then..
i really appreciate your help alot..
thanks your patiance,
Niveen
i got that file_open should be like that --> FILE_OPEN(testing_read,"abc.txt",read_mode);
i placed it after (else of rst)
i also defined these two lines
line 1-->type f_read is file of text;
line 2-->file testing_read: f_read;
and i'm still having this error
either i wrote integer or string instead of text in line 1
i don't know where is the problem.. :(
thanks alot,
Niveen..
its working now :)
i replaced line 1 & line 2 by --> file testing_read : text;
file_open() on its place @ the begining and file_close() at the end...
Niveen..
