hi,
In: assignments - settings - fitter settings - more fitter setting, there is item weak pull-up resistor I set it on and off, i found it does work. But In: assignments - assignment editor. I set value(ON) and enabled(YES) for weak pull -up resistor, i found it does not work. the device is EPM240, i don't know what is the diffenence between the two ways to contol the weak pull up feature. would the two setting be conflicted?- Tags:
- FPGA Design Tools
Did you make the assignment to a specific pin? Can you post the exact qsf file entry?
