17258 Discussions
how to simulate megafunction...
I am using Subscription Quartus with Free Modelsim Altera. I am using the LPM_CLSHIFT MegaFunction in my design. I want to simulate using the LPM_CLSHIFT running command-line Modelsim OUTSIDE of Quartus. How do I do this? I believe I need to add a library to my search path or file list, but I can't find the right name.
Thanks!
/j
hmm. i was about to point you to the EDA tab of the LPM_CLSHIFT which says it does not require any simulation libraries. looking at the RTL generated by the Wizard, you can see that it instantiates an lpm_clshift module which is part of the LPM or 220model library
the rest is in here:
http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
thanks - model220.v did the trick
