Anybody can teach me about counter? Here is my code~ always @(posedge clk) begin if (reset==1) begin readdata <=16'd0;//output x<=8'd0;//output selA<=3'd0;//output ld<=1'd0;//output end else if(chipselect) begin c<=c+1; //c is a reg case (c) (0|2|4|6|8) : begin x <= writedata[7:0]; selA <= writedata[10:8]; ld <= writedata[11]; end (1|3|5|7|9) : readdata[15:0] <= Q; endcase end endLink Copied
This is clearly the same as another thread you've opened. Close one and post all your questions, on the same subject, to the same thread
use the altera template:
// UP/DN binary counter with all of the register secondary // hardware. (1 cell per bit) module cntr_updn (clk,ena,rst,sload,sdata,sclear,inc_not_dec,q); parameter WIDTH = 16; input clk,ena,rst,sload,sclear,inc_not_dec; input [WIDTH-1:0] sdata; output [WIDTH-1:0] q; reg [WIDTH-1:0] q; always @(posedge clk or posedge rst) begin if (rst) q <= 0; else begin if (ena) begin if (sclear) q <= 0; else if (sload) q <= sdata; else q <= q + (inc_not_dec ? 1'b1 : {WIDTH{1'b1}}); end end end endmodule
