17252 Discussions
i am getting error as fitter cannot place one io_pll, cannot find a location with io_tile_lock_id of 77. this error i am getting in quartus prime 18.0. can any one help how to solve this problem
AC1
AnandRaj_S_Intel
Can you elaborate on the steps.
  1. Which edition have you used?
  2. Can you share your design?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
AC1
i am using quartus 18.0.
i am using jesd, pcie,ddr, nand and ethernet in my interface
AnandRaj_S_Intel
I have tried to recreate the issue but not succeeded.
  1. I know you are using 18.0, I have asked you about the edition(Pro or Std)?
  2. You can share the design if possible.
Or to Debug the design
  1. Can you remove the IO PLL from design and compile design and check.
  2. Recheck the IP interface/ connections.
Anand Raj Shankar
