17261 Discussions
i can't run my simulation, there is this error message. i can't really understand what is this
krond
Determining the location of the ModelSim executable...
Using: c:/users/noone/desktop/modelsim_ase/win32aloem/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog --write_settings_files=off displaencoder123 -c displaencoder123 --vector_source="C:/Users/noone/Documents/ETEC-122/Waveform.vwf" --testbench_file="C:/Users/noone/Documents/ETEC-122/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus II 64-Bit EDA Netlist Writer
Info: Version 15.0.0 Build 145 04/22/2015 SJ Web Edition
Info: Copyright (C) 1991-2015 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus II License Agreement,
Info: the Altera MegaCore Function License Agreement, or other
Info: applicable license agreement, including, without limitation,
Info: that your use is for the sole purpose of programming logic
Info: devices manufactured by Altera and sold by Altera or its
Info: authorized distributors. Please refer to the applicable
Info: agreement for further details.
Info: Processing started: Sat Jun 06 19:16:39 2020
Info: Command: quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog --write_settings_files=off displaencoder123 -c displaencoder123 --vector_source=C:/Users/noone/Documents/ETEC-122/Waveform.vwf --testbench_file=C:/Users/noone/Documents/ETEC-122/simulation/qsim/Waveform.vwf.vt
Info (201000): Generated Verilog Test Bench File C:/Users/noone/Documents/ETEC-122/simulation/qsim/Waveform.vwf.vt for simulation
Info: Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 4776 megabytes
Info: Processing ended: Sat Jun 06 19:16:41 2020
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:01
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --functional=on --flatten_buses=off --simulation --tool=modelsim_oem --format=verilog --output_directory="C:/Users/noone/Documents/ETEC-122/simulation/qsim/" displaencoder123 -c displaencoder123
Info: Processing started: Sat Jun 06 19:16:42 2020
Info: Command: quartus_eda --write_settings_files=off --functional=on --flatten_buses=off --simulation=on --tool=modelsim_oem --format=verilog --output_directory=C:/Users/noone/Documents/ETEC-122/simulation/qsim/ displaencoder123 -c displaencoder123
Info (204019): Generated file displaencoder123.vo in folder "C:/Users/noone/Documents/ETEC-122/simulation/qsim//" for EDA simulation tool
Info: Peak virtual memory: 4783 megabytes
Info: Processing ended: Sat Jun 06 19:16:43 2020
Info: Elapsed time: 00:00:01
**** Generating the ModelSim .do script ****
C:/Users/noone/Documents/ETEC-122/simulation/qsim/displaencoder123.do generated.
**** Running the ModelSim simulation ****
c:/users/noone/desktop/modelsim_ase/win32aloem//vsim -c -do displaencoder123.do
Reading C:/Users/noone/Desktop/modelsim_ase/tcl/vsim/pref.tcl
# 10.3d
# do displaencoder123.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim ALTERA vlog 10.3d Compiler 2014.10 Oct 7 2014
# Start time: 19:16:44 on Jun 06,2020
# vlog -work work displaencoder123.vo
# -- Compiling module displaencoder123
# Top level modules:
# displaencoder123
# End time: 19:16:44 on Jun 06,2020, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vlog -work work Waveform.vwf.vt
# -- Compiling module displaencoder123_vlg_sample_tst
# ** Error: Waveform.vwf.vt(31): near "-": syntax error, unexpected '-', expecting ')'
# Errors: 1, Warnings: 0
# ** Error: c:/users/noone/desktop/modelsim_ase/win32aloem/vlog failed.
# Executing ONERROR command at macro ./displaencoder123.do line 4
RichardTanSY_Altera
Could you try to open Waveform.vwf.vt with a text editor and try to understand which original waveform editor entry might show at line 31 and what's wrong with it?
