17266 Discussions
im am trying to Build a 8-bit to 16-bit left combinatorial shifter using the IF-THEN statements and im getting errors
CKiel
the specifications are athat is shift cntrl =0 then no shift if shift cntrl = 1 then shift 4 to the left, if shift cntrl =2 then shift left 8 and if shift cntrl=3 then no shift
my current code is
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.NUMERIC_STD.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity shifter is
port (
input: in UNSIGNED(7 downto 0);
shift_cntrl: in UNSIGNED(1 downto 0);
shift_out : out UNSIGNED(15 downto 0) :="0000000000000000"
end entity shifter;
architecture shift of shifter is
begin
shifting : process(input,shift_cntrl)
begin
if shift_cntrl='00' then
shift_out <= input;
elsif shift_cntrl='01' then
shift_out<= shift_left(unsigned(input),4);
elsif shift_cntrl='10' then
shift_out<= shift_left(unsigned(input),8);
elsif shift_cntrl='11' then
shift_out <= input;
end if;
end process shifting;
end architecture;
when i run it i get the following errors
Error (10500): VHDL syntax error at shifter.vhd(19) near text "'"; expecting "(", or an identifier, or unary operator
Error (10500): VHDL syntax error at shifter.vhd(21) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at shifter.vhd(24) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at shifter.vhd(27) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at shifter.vhd(29) near text "if"; expecting "process"
how can i fix this?
Vicky1
Hi Cameron, Please follow the VHDL syntax, Replace the single quote(' ') with double quotes(" ") since bit_vector literal is an array of bits & that should be enclosed in double quotes. Regards, Vikas
