17249 Discussions
implementing primitives
I am new to vhdl; I tried to instantiate a dff
I put the following at the top:
library altera;
Use altera.altera_primitives_components.all;
and then in the architecture I put the following
xxx : dff
Port map(
d => Phases_in(1),
clk => Clock,
clrn => Reset,
prn => '1',
q => Phases(0)
I get this error
Error (10500): VHDL syntax error at Position_Encoder.vhd(121) near text "Port"; expecting "(", or "'", or "."
It is like it doesn't recognize it as an instantiation. I am using the web edition, is important.
jtg
You've only posted a snippet, not line 121. This will just be a syntax error.
line 121 is the one which has "port map" on it.
If I remove the dffs from the code it compiles fine.
please post the entire file. I suspect the problem is elsewhere.
Library IEEE;
Use IEEE.std_logic_1164.all;
Use IEEE.numeric_std.all;
library altera;
ENTITY Position_Encoder IS
Port (
Reset: IN STD_LOGIC;
Index: IN STD_LOGIC;
Home : IN STD_LOGIC;
Clock: IN STD_LOGIC;
Phases_in: IN STD_LOGIC_VECTOR (1 downto 0);
Position: OUT INTEGER RANGE 0 to 500000;
Present_state: Out std_logic_vector (2 downto 0);
Error: BUFFER STD_LOGIC
END Position_Encoder;
ARCHITECTURE logic OF Position_Encoder IS
TYPE State IS (state00, state01, state10, state11);
SIGNAL pr_state, next_state : State;
SIGNAL temp : integer range 0 to 500000;
Signal Phases : std_logic_vector (1 downto 0);
BEGIN
PROCESS (Reset, Clock)
BEGIN
IF (Reset = '1')THEN
pr_state <= state00;
temp <= 10;
ELSIF (Clock'EVENT AND Clock = '1') THEN
CASE pr_state IS
WHEN state00 =>
Present_state <= "000";
IF (Phases = "00") THEN
Error <= '0';
ELSIF (Phases = "10") THEN
pr_state <= state10;
temp <= temp - 1;
Error <= '0';
ElsIF (Phases = "01") THEN
pr_state <= state01;
temp <= temp + 1;
Error <= '0';
ELSIF (Phases = "11") THEN
-- Error <= '1';
END IF;
WHEN state01 =>
Present_state <= "001";
Error <= '0';
ELSIF (Phases = "00") THEN
temp <= temp - 1;
-- Error <= '0';
ElsIF (Phases = "11") THEN
pr_state <= state11;
temp <= temp + 1;
Error <= '0';
Error <= '1';
END IF;
WHEN state10 =>
Present_state <= "010";
Error <= '0';
temp <= temp - 1;
Error <= '0';
ElsIF (Phases = "00") THEN
temp <= temp + 1;
Error <= '0';
ELSIF (Phases = "01") THEN
Error <= '1';
END IF;
WHEN state11 =>
Present_state <= "011";
Error <= '0';
Error <= '0';
temp <= temp - 1;
ElsIF (Phases = "10") THEN
temp <= temp + 1;
Error <= '0';
Error <= '1';
END IF;
END CASE; --end: CASE pr_state IS
--temp <= temp + 1;
Position <= temp;
END IF; --end: ELSIF (Clock'EVENT AND Clock = '1') THEN
xxx : dff
Port map(
d => Phases_in(1),
clk => Clock,
clrn => Reset,
prn => '1',
q => Phases(0)
delay_2 : dff
port map (
d => Phases_in(1),
clk => Clock,
clrn => Reset,
prn => '1',
q => Phases(1)
end process;
END logic;
Here it is. I appreciate your taking a look.
you cant instantiate anything inside a process. Instantiation has to be done outside a process.
Thanks alot. I appreciate your help. Life is good ... well better now.
jtg
