Hi ,
I am using Quartus Prime ver 16.0 lite edition , i tried to import pin assignments for my DE2-115 board from a excel file "DE2_115_pin_assignments.csv" , compiled the project but i noticed the fitter didnt assigned and pin as per .csv file . I tried the manual approach and from within Pin Planner clicked on the CLK pin and tried to change its assignment , but a message poped up that its read-only ??? . This a new project creation . How do i import and force fitter to assign pins as per .csv file ???? Regards , AhmedLink Copied
Maybe I missed a *.csv import option, I'm always importing pin assignments as tcl commands like
set_location_assignment PIN_M20 -to LED_Blue
They can be easily generated in Excel.
--- Quote Start --- Maybe I missed a *.csv import option, I'm always importing pin assignments as tcl commands like
They can be easily generated in Excel. --- Quote End --- How can it be generated in Excel ??
Is this the only way to set pin assignments in Quartus Prime ver 16.0 lite edition, i have also tried importing .qsf file , but it had no effect ????
So i have to revert back to the old version of Quartus then ????- Mark as New
I wrote my own tcl script for pin assignments , included the file in the project and tried to run it from within tcl console but no success , there are some errors as shown below
Error:invalid command name "UART_nu.tcl" Error: while executing Error:"unknown_original UART_nu.tcl" Error: ("eval" body line 1) Error: invoked from within Error:"eval unknown_original $cmd $args" Error: (procedure "::unknown" line 7) Error: invoked from within Error:"UART_nu.tcl" dir Error:invalid command name "dir" Error: while executing Error:"unknown_original dir" Error: ("eval" body line 1) Error: invoked from within Error:"eval unknown_original $cmd $args" Error: (procedure "::unknown" line 7) Error: invoked from within Error:"dir" UART_nu.tcl Error:invalid command name "UART_nu.tcl" Error: while executing Error:"unknown_original UART_nu.tcl" Error: ("eval" body line 1) Error: invoked from within Error:"eval unknown_original $cmd $args" Error: (procedure "::unknown" line 7) Error: invoked from within Error:"UART_nu.tcl"- Mark as New
the tcl file is saved as "UART_nu.tcl"
I can't help much without seeing the script, but as far as the Pin Planner is concerned, try closing your project and trashing the db folder. Then reopen your project and go back into the Pin Planner to try to make manual assignments again.
As far as the .csv file is concerned, I'd have to see the format you have in the file. If the format is not correct, you won't be able to use it for import.- Mark as New
Solved the problem , within tcl console i wrote "source <de2_pins.tcl>" and it worked
